Tool Chest Question
jhutch690
Looking at buying a US General Box to replace my Craftsman that I have outgrown. I was set on buying a 26 top and bottom but after looking at them today my thought was a 44" with a 26" top. Will that look odd? My reasoning is I like have a space on the bottom box free to store tire gauges/air chucks/misc items.
Tell me why the 44" is better than a 26"?
Thanks,
StreetGLi
Thanks,
The easy answer is that the 44" is bigger. If you have the funds and the space, you'll appreciate the extra storage. I have a 26 top and bottom. It matches and it looks nice and it was on clearance so its fine, but I do wish the bottom cabinet was bigger so I could store some larger items out of sight. However, my garage is small and space is at a premium and the price was right.
Sent from my LG-H873 using Tapatalk
Bessy
Ontario, Canada
Not the same boxes, but I do have a 26" top on a 42" bottom box right now (42" top is on order currently). With the 26 the biggest thing that annoys me is the difference in depth, I always end up setting something on the 6" ledge in front of the 26, which I then have to move to open the drawers.
I'd suggest sticking with the bottom for now and use the top for a work surface, if/when you need the extra space, consider going with a 44 top and/or add the five drawer cart.
Sent from my Pixel using Tapatalk
MushCreek
Upstate South Carolina
In my work as a tool maker, I've always had a smaller top box, as I have things that need to sit on the chest, alongside the top box. My favorite set-up is to buy or build a riser for the top box. Make it open in the front, so you can store small stuff underneath. Using a riser eliminates the problem of stuff getting parked in front of the top box. Plan a height that still allows you to comfortably see into the top box. I use the same set-up on a workbench where I have a tool box, and don't want the bottom drawer to get blocked.
vavet
Ashland, VA
It matters not if it looks funny. I have a 26 inch Craftsman top box on top of my Matco 2 bay rollaway. This allows me space on the Matco box to have work. If I could find a top box for my Matco for a good price I’d gladly jump on it and find a new home for the craftsman box.
dumper
Oregon
how about the 44" with a side box...or two! Think of all that work space on top. There are some guys here who have that setup, maybe search for a few pictures. Just found this example...(not mine!)
brownbagg
im tired of having top boxes, you either have to moving something to open the bottom drawer, or too short to see in the top drawers. if i could redo time, I would never have a top box
tez929rr
Welfare, TX
I did exactly that - used to have a narrow tool chest and a workbench and replaced both with the set up in your picture. I rarely move it but when I do the work space moves with it.
Elvisidal
Australia
I’ve never had a top box.* 26” 7 drawers has done fine for 27 years
Gotta open the lid to open a drawer?? yeah nah **** that :)
* there is currently some top box I’ve borrowed while I do an end of year clean out and after 2 days it’s pissed me off no end :mad:
MushCreek
As in all tool box set-ups, it depends upon what kind of work you're doing, and how many tools you need. In recent years as a tool maker, I eliminated the top box because I needed the horizontal work space. My box is my workbench. I have a granite surface plate on top of my 44" HF. I carefully weeded through my tools and found that there was plenty of room in the 44. At home, I have plenty of bench space, the shop is much smaller, and I need storage for lots of mechanic's tools. My HF 44 at home has a 44 top box, and an added side box. Lots of storage, and a small horizontal surface as well.
Rickster
SE PA
I'd recommend full top or mid box, not smaller... unless you can keep the area in front of it clear.
machsnell
Northern Virginia
I like having space on top of my box.
Also hard to see in top box if you have a decent height bottom.
I moved up from my gesrwrench 44 and roller cart to a 29" deep x 56" Matco. I wish I had gone to a 72 and just been done with it. I am already out of space.
So my vote even tho not your question is to bypass 44 and go 50-whatever or do 44 with side cabinets. Just hard to move around with sides.
Sent from my SM-G960U using Tapatalk
