tool Definitions And Uses Explained
z28toz06
Connecticut
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, splattering it against that freshly
painted part you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere
under the workbench with the speed of light. Also removes fingerprint
whorls and hard-earned guitar calluses in about the time it takes you to say, "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija board
principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various
flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new disk brake pads, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off a hydraulic jack handle.
TWEEZERS: A tool for removing Douglas fir wood splinters.
PHONE: Tool for calling your neighbors to see if he has another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for spreading mayonnaise; used mainly for getting dog Sh*t or horse Sh*t off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on
everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry bar that
explicably has an accurately machined screwdriver tip on the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBL E LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine vitamin," which is not otherwise found under cars at night. Health benefits aside, it's main purpose is to consume 40-watt light bulbs at about the same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of old-style
paper-and-tin oil cans and splash oil on your shirt; but can also be
used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a
coal-burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts last over tightened 58 years ago by someone at ERCO, and neatly rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or
bracket you needed to remove in order to replace a 50¢ part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts not far from the object we are trying to hit .
MECHANIC'S KNIFE: Used to open and slice through the contents of
cardboard cartons delivered to your front door; works particularly well
on contents such as seats, vinyl records, liquids in plastic bottles,
collector magazines, refund checks, and rubber or plastic parts.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also the next tool that you will need.
EXPLETIVE: A balm, usually applied verbally in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight.
iiibdsiil
Tampa, FL
Oh, like my Snap-on flashlight? Bulbs don't get a chance to burn out. Then realize you used the last spare bulb the last time you got pissed off. Then, use a lighter as a flashlight, on a job that already requires 3 hands, and some how end up actually getting the job done faster.
I have no idea what you are talking about ;)
joecaver
Dallas, GA
Re: [b]tool Definitions And Uses Explained[/b]
the fact that they are all so true is what's so funny. I think I've done most if not all of those.
Bradley Miller
Blue Springs, MO
I like to frequently use sockets to find the centerline of the car, because if it falls, it will always be in the MIDDLE of the car where I can't reach it . . . that's providing it even made it to the floor and didn't get caught up in a cranny or nook and didn't hit the floor at all. That dreaded "thud" sound where it should have been a nice "kerplat" against concrete. DOH! That's usually a good point for a beer run and the trusty flashlight and mirror to figure out where the offending socket is and how exactly I'll have to use the "springy three finger never reach it thingy" to attempt to coax it to an even more precarious position. *Sigh*
Bradley Miller
Blue Springs, MO
SNAP RING PLIER -- this cunning device is capable of being used as a 3rd world country's missle defense system, putting those un-obtanium snap rings crucial to finishing that project at 1:30 AM in the morning into a low-level earth orbit . . . or just far enough under the corner of junk that it'll never be seen again. Another beer run is in order.
