Tool for cutting fiberglass sheets?
David9726
The fiberglass sheets are 12x12 and 2, 4, 6 mm thick i've been using a dremel cutting wheel but it makes such a mess. The cuts are mostly straight with a few angles. The dremel works but makes a ton of fiberglass dust that can't be good for your lungs. These sheets are FR4 epoxy/glass laminate.
Is there a specialized tool to cut this ****?
Xti04
I second both of those suggestions. Those are my tools of choice for cutting up fiberglass jet skis to install custom stuff they should have no problem with the thin sheet. If you want you can clamp it to a wood backing so it doesn't vibrate as bad.
rwa2004
Western PA
We cut a ton of it at work and do it all with a carbide blade on a table saw. The small detail cuts are done with an oscillating cutter.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Marctrees
TX/LA border - Toledo Bend
I would definitely go w table saw w fine blade, parallel cuts against fence, angled cuts on a sled.
A proper blade should give beautiful smooth edge.
Put a layer of medium sandpaper on the sled bed.. when firmly held down onto that, will not shift when cutting.
Sounds good to me... only concern I would have is would the dust cause abrasive problems in any way on the saw?
Getting into bearings, etc ?
Could just buy a used one, like old Craftsman on C list for $150 - $200 for this use, if you do alot of it.
Marc
danski0224
Near Naperville, IL
Fiber cement board shears might work. Might be worth a shot if you can borrow one to try.
Double cut shears or a Unishear may work. These work on some sheet plastics.
Michigan Mike
Kalamazoo Mi.
If these are anything like the FRP I used to install I used to use a cabide scoring knife for the straight cuts. Score it a couple of times then break it.
sierradmax
Rhode Island
We cut alot of 3/4" FRP plate with continuous diamond grit wheels. For curved pieces, diamond grit sawz-all blades. Grab a friend and use a shop-vac to collect the dust.
Marctrees
Actually for the thinner stuff, score and snap against straightedge of workbench may be best.. quick cleanup of edges w hand sanding block ??
I dunno, if not w plain sharp razor knife, then w a regular old style Laminate "Formica" hand dragged scorer ?
Michigan Mike said a carbide scoring knife.. I have never seen that.. the cheap Formica scorers I have used are more like just hardened steel.
If you dont know, they have like a hook end that digs into the material deeper than a plain razor knife... You take a few multiple passes to dig a deeper groove w each pass, then snap down along edge of workpench.. cleanup w sandpaper or appropriate file.
Marc
Michigan Mike
Kalamazoo Mi.
Marc the carbide knife is just a heavy duty version of what you use. Mine were originaly used for formica work. The carbide tip means it will score almost anything. Using one of these does limit the amount of dust produced. I prefer it over any saw cut.
mike93lx
Richmond, VA
You aren't doing this without breathing protection, right? That would be insane...
danski0224
Near Naperville, IL
The shop vac crowd should be using a HEPA rated vacuum, and not just any old "shop vac" with a "HEPA filter" in the canister.
Otherwise, the particulate matter that will harm your lungs just blows right through the vacuum, back into the air you are breathing.
