Tool for drilling glass?
F
Fugio
Do they make a diamond drill bit that big? I mean is it a common HD type thing? You think the Dremmel is how they do it?
jim whitney
Winchendon ma.
Ceramic tile cutting drills at lowes or Home Depot or local hardware store I made over sink lives for wife out of old green insulators takes some time but it's possible
NUTTSGT
Northern Central Ohio
Sounds like it might take a bit more than just drilling a hole. From the link behind the picture.
Plastic night lights have the backs cut out in order to change the bulbs and the glass night lights are flattened and attached with a clip.
http://www.hometone.com/bottles-could-light-up-so-well.html
We are going with some friends this weekend and the plan was to grab a few "shot" bottles. I might have to try to duplicate some of these. . . . Bacardi and Grey Goose.
F
Fugio
You can flatten bottles in a forge. We've done that. The results are amazing.
But these little bottles don't need bulb changes. We're gonna use LED lights.
06switchback
Try this
Google
Cutting glass with fire
Go have a couple beers and practice on the emptys
Sent from my SAMSUNG-SGH-I537 using Tapatalk
VictorBravo
Asotin County, Washington
The old telescope maker's way of drilling glass is to take a steel pipe and use silicon carbide grit under it. Takes a while, you can't go too fast, but you get accurate holes.
The more modern way is to use a holesaw with the teeth ground off and grit. I've done it on a finished primary mirror and it was tense (the glass was worth over $400 before all the polishing work).
Scroll down about a third of the way in the link to see what I'm talking about. They guy there references diamond impregnated cutting tools--I'm guessing some tile holesaws as noted above would fit the bill.
http://mirrorworkshop.mtbparker.com/cassegrainStory.html
oldldh
Fairhope, AL
Buy all you want. They are surprisingly cheap.
I drilled a bunch of drain holes in about 50 ceramic flower pots...
I used a diamond drill bit from Loew's. and the world famous Harbor Freight $ 59.99 drill press...
The drill bit cost twice as much as these...:sad:
And...
I'll order these, this weekend, in case my Wife needs more pot holes...(Why doesn't that sound right???):headscrat:evil::lol:
mdd1986
Not sure how big the holes you are drilling are but I have had great luck with diamond coated hole saw drill bits. I usually drill the sides of fish tanks for bulkheads. The best method I found is to use a small puddle of water to keep the bit cool and just let the bit do all the work. Do not press down on the drill or you will crack the glass!
http://www.amazon.com/dp/B0076UIOVE/?tag=atomicindus08-20
Brian_WK
NE South Dakota
I think it would be socially awkward if I were to put one of these in my kids room... The only place in my house that has a night light...
On topic. Those diamond core hole saws work great. Proper cooling is a must. We drilled about 30 of those hollow glass blocks for lights a few years back with a 1 inch core hole only cracked one block. Drill press with wood blocks on vice jaws then a milk carton cut off and filled with water submerged the block in the water and ran it on its fastest speed and drilled the holes with the area submerged. Took about a minute to drill through 1/4 - 3/8 thick glass using little to no pressure.
Brian
jmarkwolf
Southeast Michigan
In high school, I used to drill holes in the bottom of mason jars for a lady who made table lamps out of them.
I used copper tube with a cross-slit on the end, valve lapping compound, and a drill press.
Took a little while, maybe 20 minutes each hole. Never broke one.
Lassen Forge
Appropriate sized diamond hole saw, as slow as you can get, with plenty of water for cooling / lubrication, and steady down pressure - do NOT **** the drill whatsoever (aa good drill press is a lifesaver). Take your time and it will work. We had to duplicate some 1930's fixtures (ncluding holes in mirrors) in a building we were maintaining - the first time was dicey, the second, not so much. By the 10th it was routine.
06switchback
Grease impregnated string around the bottle, light it and once it starts to burn hot, dunk it in a bucket of water ?
I have never tried it just seen the video a while back
cgds92
Raleigh, NC
Ive used a roto-zip with tile bit to cut holes in wine bottles for Christmas lights.
Sent from my GT-N5110 using Tapatalk
