rattle_snake
Looking for a tool or set used to mark hole centers from the edge of material. Or also a corner.
Thanks. Looks like same concept as the link in post #1I use an Incra Tee rule for those jobs
INCRA TOOLS :: Woodworking Measuring, Marking and Layout Tools :: INCRA Precision T-Rules
INCRA T-Rules make it very easy to draw exact lines in either direction. Select the proper slot or hole, insert a .5mm mechanical pencil, and mark the measurement with dead-on accuracy.incra.com
-I bought a cheap 6 inch dial height gauge like this a long time ago for lay-out work like that. It has a carbide edge that can last for decades if used carefully. A magic marker, a surface plate, and a light touch makes clear scribed lines quickly that are more reliable than most other methods. It's faster and more accurate than a combination square.Mostly metal. I often want a series of holes centered on a 1" flat bar, for example. So 1/2" in from the edge. Or a corner, 1/2" in from both sides. Use a sharpy or a punch to mark center.
Link? search term?
So, ignorant question, how does one ensure the hermaphrodite caliper stays even? Does one trace exactly on the top edge of the plate, count on the flat spot on the leg staying square, or ??The old fashion method would be to use...., hermaphrodite caliper, to mark a line from the edge,
And then, to use a set of dividers to mark even spaces along the first line.
Use of a hermaphrodite caliper to scribe a line parallel to an edge is not “idiot proof”.So, ignorant question, how does one ensure the hermaphrodite caliper stays even? Does one trace exactly on the top edge of the plate, count on the flat spot on the leg staying square, or ??
Thanks
A rivet fan can evenly space the holes between the end points.I often want a series of holes centered on a 1" flat bar, for example.
