Tool ID Help
I just saw one of these online this week so I actually know what it is.
HERE is the page it was on and its a ...
It should have a rubberised covering on the handle
Modern ones maybe. That one would have had wood slabs on the sides like a knife. See those rivets? The wood either rotted/split off, or it may have gone through a fire.
demographic
The Duchy of Grand Fenwick, otherwise known as Gre
Doubt it, that looks just like Estwing hammer handle without its leather washers or its plastic grip.
Those rivets look cast in place so I doubt they have been put in place through wood.
Plus, the metal is thins down where the rubberised part goes and if it were wood slabs I suspect it would be too thin.
I think those bits you are calling rivets are actually cast in place and are there to stop the rubberised grips from sliding off.
2mJps
north central Mo
I saw 1 on a fire rescue truck and was told they used it to break windows with the point cut out windshields with the axe.
Could be. :dunno:
retDAC
near Huntsville, Ala.
It looks like the retainer on the **** is broken off. I have an unusual ball peen hammer where the head and handle are one piece with washers for grip material. Some are missing as the **** is broken off and in the pix, this looks almost identical to the broken end of mine.
demographic
Is yours an Estwing?
Like the one shown on this advert showing tools in 1939?
The versions with the blue rubberised plastic grip have this under the rubber
Like this picture I found on the net.
On the hammer with the stacked leather grip there's no lanyard hole and prongs on the end go through the endplate and are peened over.
What people naturally assume are rivets are actually the ends of the steel shaft.
Like this.
medium
Now, I've seen several blue handled Estwings over the years where the grip has slipped slightly and can only assume that the bumps on that fire axe are there to stop that from happening.
I've got two Estwing hammers that need a few more leather washers to replace the crappy plastic ones Estwing insists on using several of. They get damaged when the user overstrikes and I suspect that UV light also makes them brittle.
The leather washers last a lot better than the few plastic washers in my opinion.
I'll get round to it at some point.
Incidentally, you don't know just how many pathetic, dweeby little "Zombie killer" site images I trawled through on Google images to find the top image.
Sheesh, those kids just need to get laid.
