Tool mounting to garage floor-Best way for multiple items?
trs71
Hey- I'm FINALLY getting the garage in order. It's a small 2/12 packed garage. I've got 4 or 5 things I need mounted.
I'm using red devil threads, so I can unbolt the items and drag them out of the way.
I'm mounting close to the front of the garage I think, and you'll need the door open to use it. I was going to mount outside on a slab but eh- I'll leave the vise there mostly I assume.
Now the question. 1 lousy hole will line up on all the tool bases , bolt patterns are way different. Is the some brackets to facilitate hold down, or do I need 15 holes?
Or some other idea some one did? Thanks.
hans109h
Upper Midwest
I started my holes with a manual tire changer, then welded up a matching base for the vise using the same hole pattern.
When neither are in I have set screws to fill them.
If I did it again I would get a drill (Hilti?) That mounts to the floor so the anchor hole is plumb, and instead of set screws i'd find a rubber plug to speed things up.
Hans
nadogail
Coronado, CA
I like to mount things to a rim with a tire on it so it is solid, but can be moved. Truck Brake Drums also are useful as pedestals,
Zeke
But then you have several rims taking up real estate. I do this too, so I'm not bitching. But a horizontal equivalent to the old hitch receiver set up sounds like it would work here. I don't mean to put a hitch receiver in the concrete although that doesn't sound awful.
nadogail
Coronado, CA
Everyone has their own opinion, and very few people will agree.
My workshop is in a two car garage and my son parks in it at night.
He thinks it’s his garage; it is my workshop he has the privilege of parking in.
T
trs71
Hans
How flush do the screws sit? I was wondering the best way to plug them.
make a common base bolt layout & adapt everything to that, either drill holes or plates to adapt
What gauge scrap metal for the base?
I like to mount things to a rim with a tire on it so it is solid, but can be moved. Truck brake drums also are useful as pedestals,
Then 5 rims to move and the space
Lol cars IN a garage, now I've heard everything.
I gave that up in 1996 :)
Spareparts
Lansing Ks.
I put a 4" square tube w/ 3/16" wall thickness in my floor flush, then mounted tube bender, bead roller, small metal brake, and a 8" grinder all on 3 1/2" pedistals. Picked up a 400lb overhead hoist to move things around. Sure saves the back.
hans109h
Upper Midwest
My anchors are recessed about 1/4 inch below the floor. I was concerned about them filling with dirt but it really hasn't been an issue.
T
trs71
I never thought of mounting a receiver on the floor,but I have on my workbench. Anyone got a pic or 2...?
Monza Harry
Windsor ON
But...... I don't mean to put a hitch receiver in the concrete although that doesn't sound awful.
I plan on doing just this! Primary use planned is as a winch anchor, for dragging in dead carcasses. However I did consider the functionality of it as an anchor for a couple of my benders, rire machine etc. Perhaps with a some lead sheaves for some screws. So Zeke I have thought that is a good idea for a couple of decades so far, maybe one day I will "make it so" Harry
