Tool to remove wheel bearing dust caps
noid
Alright folks, we have ourselves a bit of a situation; I'm about to change wheel bearings and the dust caps been backordered from the only source (dealer) for over a year, so we have to get them off without damaging!
Before I go out and buy this tool that looks like its been around since at least the 1950's, is there a better tool out there?
Really looking to better the chances over using a screw driver and hammer as its a very thin dust cap.
esben57
Sheffield. England
Would a trim tool such as this do? More edge than a screwdriver, should get it moving.
My 70's/80's Stanley comes in handy
mitusa
SW Oklahoma
I always use two hammers.....a claw hammer with the claw between the lip of the dust cover and hub....put a little outward pressure on it and hit the hammer head of the claw hammer with another hammer.
It always works for me and doesn't screw up the dust cover.
hths
I slowly went around with a chisel on my 2003 BMW 330i and bent the lip just a bit to relieve tension
Great use for a thrashed / loan to the neighbors chisel. A slight twist of the bit can help leverage it out too.
bonneyman
Desert SW
Nothing I've tried would get grease caps off without damage. Then you "tap" them back on with a hammer and they get dented! Yuk!
I've always wanted to get one of these older Bonney pliers. They're called battery terminal pliers but I think they're more towards grease cap removal. Maybe someone else makes the style, or someone could weld some half-moon flanges onto a pair of long handled pliers.
redmondjp
Redmond, WA
Before recently obtaining the pliers shown at the top of this thread, I would use a cold chisel, at the proper angle, which usually will get the cap moving a bit so larger devices can get behind the lip in order to apply more force to the cap. Very minimal damage if you are careful.
Steve_P
Before I bought the Vim pliers, I got the best results from a freshly sharpened ~.06" thick scraper and hitting it with a hammer. This worked better for me than a chisel as far as getting things started- I tried a chisel also. But the OP wants the proper tool, so....
Banjorear
Essex Co., NJ
MAC Tools made the best one back in the '80's. I forget the part number. My buddy has the same tool and I will ask him for the part number and report back. The MAC is better than the Snap On one recommended above. I have that SO tool as well.
jsaw
Geneva, N.Y.
Depending on the style, I use a pair of 16" channel locks , being very careful to not squeeze to hard . I grip the cap and rock it back and forth, then rotate 90 degrees and rock it again. It usually comes off.
whateg01
doo dah, kansas, usa
I've always used a small chisel. Tap it under the lip, working your way around the cap. Then once it's up a little do the same but twist to lever it out more. I have often just tapped the cap back on and yeah it dents it, but on a trailer or an old work truck, who cares. On the one vehicle I needed them to stay looking decent, I turned a tool on the lathe to fit over it and only push on the lip.
WildBill
PNW
I had no idea there were tools for this, I have always used an ancient gasket scraper to remove and a rubber mallet to gently replace.
American Locomotive
Rhode Island
Those tools work great. I usually just use a thin screwdriver or a chisel and carefully work my way around.
Also, there isn't anything particularly special about dust caps. You could measure the ID of the situation and find a replacement cap somewhere.
whateg01
There are some oddball sizes. I had a trailer awhile back that I never found a fitting dust cap. Ended up with a slightly smaller one and turned a bushing on the lathe to make it fit
jsaw
Geneva, N.Y.
Grip it carefully and rock it then grip it 90 degrees and rock it again. It will come off
demarpaint
Long Island
I either rocked them off with with Tongue and Groove pliers or used a small flat blade screw driver and worked my way around the cap. I never had a problem getting them off.
Jon h
Ottawa, Ontario
hths
I second the claw hammer……and this is the ONLY time I will use a claw hammer on a vehicle…..
It really does work well.
Jon h.
FigN⋅m
Jon h.
thirded - I inherited a Dead On forever ago and it lives in the 4Runner as a general purpose persuader
and perfect dust cap remover, as the claw edges seem a bit sharper than a typical claw.
DGersic
DeKalb, IL
And if you don't have a welder? C'mon, this is a simple task that doesn't require a welder if you have the proper tools.
Make the hole a little bigger and put a grease zerk in it to mess with the next guy that has to remove it.
