Toolbox addons
alpaca
I'm looking for one of those screwdriver holder things that goes on the side of a toolbox (you know with the holes in it so you hang screwdrivers/pry bars vertically). Anyone know what I'm talking about and where to get it?
A
alpaca
nvm that's it just isn't what I pictured, thanks
alinc100
Dearborn,MI
Do you need it to lock/be secure or is it just to get long bulky items out of the drawer?
If the latter I re-purposed some wire closet shelving into a holder for my prybars with some scraps I had laying around. Used the same clips as if it was to be mounted in the closet.
beakie
Ontario, Canada
that's pretty good idea.
to add to it, if you had the means you could bend the bottom "squares" out 90* to keep the tools from swinging around.
paint it black and it would even look the part.
wafrederick
Holton,Mi
Another option is take a piece of aluminum and drill holes in it a little bit larger than the shank.The phillips screwdrivers are easy,drill out a 9/32" hole for the #2 phillips screwdrivers.For mounting it on the side of the toolbox,drill holes in the holder and mount to the toolbox using the factory bolt holes in the toolbox.
ADSR
That's a good idea right there! :bounce:
