Toolbox risers/spacers
JS428
IN
Hey everyone, new member here.
So i have a new mobile workbench thats going to be stationary most of the time but on a rare occasion might get pulled out. The one item i slide under my current workbench is a floor jack. I want to be able to store it under the new one. Literally its a half inch too short. Stumbled across a thread where one or a few guys mentioned using risers/spacers in between the casters and the bench. Probably gonna try to use 1/2in aluminum plate and cut out the rectangles to fit the caster plates. Has anyone ever done this and did it cause any issues?
bri_man57
Windsor Colorado
That idea should be fine. I assume the bench is solid enough to be moved, half inch to three quarters inch shouldn't make a difference
Sent from my SM-N920T using Tapatalk
kbs2244
It dosen't have to be metal
Give yourself some room to work
A doubled up piece of 1/2 inch plywood would work well
J
JS428
IN
I was thinking that at first but after talking to a few buddies they both mentioned the wood might compress overtime.
J
JS428
IN
As long as it fully supports the box, it shouldn't be an issue.
Would it fit if you simply removed the jack pad ?
Its the backside of the jack that doesn't fit. Its low pro so it slide under no problem, most of the way haha. Theres about 8in that hangs out. Im just a stickler and want it tucked under completely.
NUTTSGT
Northern Central Ohio
That would is only going to compress when you tighten the fasteners down.
Any compression from the box, if there is any, will never be noticed.
NUTTSGT
Well if the jack pad fits under it, jack the box up and slide a block under the caster.
If you need to move the box, jack it up and slide the block out.
Go a chunk of PT 2x6 lumber laying around ?
J
JS428
IN
Thanks for all the input guys! After i make a few calls tomorrow ill let ya guys know what i do and post pics later this week! Thanks again!
J
JS428
IN
See thats kinda what i thought. Just in case i thought of maybe trying to find a piece thats 5/8 thick. Now ya got me going back to my original idea haha.
p00p
42.4974° N, 82.8964° W
The fastener shouldn't compress the wood. The caster's plate will sandwich the wood between the tool bench/box frame. Any torque applied to the fastener that would severely compress the wood is likely to split the wood or snap the hardware before reaching that ability imo.
gearhead1
NC
I don’t think it will. The studs in the wall in your house are in compression. You may get localized compression if the fastener head is directly on the wood, but not so much if the load is spread out.
gearhead1
NC
+1. I agree.
NUTTSGT
True, I was just thinking of the fastener being in the wood, but it'll be sandwiched like you mention.
Still no compression in the wood to worry about.
:beer:
J
JS428
IN
OH NO, you don't get off that easy. Now you've gotta post a picture of the jack slid into place or it never happened!:D
Before, it would slide under then stop when it hit the top of the slope. Stuck out rough 6 to 8 inches and it was bugging the **** outta me. Perfect fit now! Ill post another pic in the coming days of my completed work area.
Sent from my SM-N986U using The Garage Journal mobile app
vavet
Ashland, VA
FWIW, I just did some compression testing on LSL lumber at work. A 6" long 2x4 compressed about 0.060" when under a 2000lb load. I loaded it in the 6" direction. The load was applied over about 3 minutes and then released.
It might compress more over days, weeks and years, but I wouldn't expect it to even be measureable without a micrometer for a 1/2" spacer under a toolbox.
gearhead1
NC
That’s the power of GJ. Someone on here has experience at whatever the given issue is.....
unslow1
Illinois
That's how I did one of mine. I put slightly taller ones in the front because the drawers had a tendency to slowly creep out after I disabled the latches. I store oil and antifreeze drain pans under mine.
ArkTinkerer
You could replace the casters with a larger set. Of course blocks are cheaper.
This^. SnapOn and some other big dollar boxes have decent size casters to start but most don't. Unless your casters become so large the box stability is questioned I would increase caster size. I almost always replace my casters with larger ones. Many of the original casters will bring your box to a screeching halt if you try and roll over a nut or even a washer on the floor.
p00p
a ziptie always wins the rolling wheel fight...
cassidy
Jeromesville, Ohio
I wanted to raise my toolbox at work up so I made these out of a piece of square tubing I got from the salvage yard for $20.00 They worked out good IMG_4678.jpg
