I have learned the hard way what tools to get over the years. This drain removal and installation tool is great.
You can either put a screwdriver through the holes to turn it, or stick a wrench on it to turn it. It's nice because it's easier to not strip out or damage the threads in the plastic drain flange by using this tool. Also put the rubber gasket that comes with the drain the tub in between the flange and the underneath of the tub. I put it under the lip of the drain itself the first time by mistake. And also use some tape to take the flange to the underside of the tub to hold it in place to make it easier to screw the drain into it.
And roll up some plumber's putty to put under the lip of the drain. Also the Basin Buddy is great for removing and installing supply lines and faucets. You can put a long extension on it to easily get to the connections.
Plumber's putty, PVC primer/cleaner, PVC cement, teflon tape are important to have on hand. I brought my Oatey PVC cleaner and cement over to a friend's house to repair their drain only to find it had solidified and was now useless. I had to send him down to buy more. It was in my basement, so I guess it got too cold.
Also, the HF el cheapo screwdrivers are nice to have on hand because if they get nasty dirty, it's not as bad as getting your good ones filthy. Also, general tools like pliers and channel locks are important.
What other tools? I haven't started to solder joints yet, so my plumbing skills are only at the drainage, toilet, faucet level.
