Tools every mechanic needs
mrpowderkeg
Bismarck North Dakota
dial indicator, and a caliper or micrometer it doesn't have to be expensive either, but I have seen some jobs that failed and broke because eyeballing clearances doesn't work.
rocketman
Chicagoland
A decent bench vice to hold sh*t.
Mapp gas torch for the eventual stuck nut/bolt.
DVOM for the electrical issue you will face.
Assortment of hammers to beat unwilling and unmovable parts into submission.
A piece of pipe that will fit over the end of your longest breaker bar cause eventually, it won't be long enough.
Good compressor for all the air tools you wish you could buy.
Lights, lots of em' so you can see what the hell you are doing!!
bmxr4life87
Bixby Oklahoma
hand held propane torch for stubborn fastners (new bottle can be had for under $5 at walmart)
DVOM
Scan Tool (not code reader but actual scan tool)
Factory Manual for whatever your working on
Long Pliers
Long Pick Set
Hammer Assortment
Prybar Assortment
Wide assortment of chemicals such as brake clean, lube, grease etc
tatra
pirate contest city
Working as a truck mechanic, one of the many things needed is an o+a torch!
often reffered to as the blue tipped wrench
surprised nobody mentioned a church key, in case a buddy stops by with non twistoffs, oh the horror:beer::lol_hitti
c39er
Seattle, Washington
All of the above tools and a set of Gojacks and a good anvil! You can never get all the tools you want!
Bob
mrpowderkeg
I got pissed and bit the bullet, and purchased this last weekend.... I consider it an investment, and it's made in USA
63201_main
A_Pmech
IL
A nice big Copper hammer. Those lead shot plastic "dead blow" things have nothing on a 2lb copper hammer with about a 10" handle. A lead hammer works well too.
DashEight
A can of kroil.
Craftsman 3/8's flex head ratchet,doubles as breaker.
a few hockey pucks.
MAD
Western MA
There are some repairs that to just get them started, you need a pair of big brass nuts.
atikovi
Suburban Washington DC
Sorry for the big pic. Mityvac pneumatic sucker. Makes brake fluid changes a breeze. No more squeezing a hand pump until your arm is sore on difficult bleeds. Just connect it and come back 5 minutes later. Also great for transmission fluid changes if the pan doesn't have a drain plug. ***** the ATF out of the pan before lowering so no spills or hot fluid down your arms. Best thing for bleeding Ford PS systems after replacing a rack. No more whines from air in the fluid.
Monte
Germany
Deep hole markers and deburring tool (not only for metalworking but for cleaning threads from teflon tape, loctite, dirt etc. )
DashEight
I'd add a phone to call for back-up. Hell you can never own or know everything. But knowing someone to call in the clutch is priceless. Make sure the folks that help you out know that you apperciate it. It's free and always in good form. -Patrick
Fedwrench
Valley of the sun
Two additions I thought of when reading the newer posts. First, the Mityvac pneumatic fluid extractor is the best thing since sliced bread. However, you want to be careful removing hot fluids such as oil, ATF, or coolant. I have seen more than one shatter. If you're going to remove hot fluids, I would recommend an all metal unit from John Dow or others.
Secondly, no one tech has seen everything and has all of the answers but, there is a place for professional techs where you can pick each others brains, search through thousands of real tough repairs and their fixes, and get more real world knowlege than you ever realized existed. That place is iatn.net it will run you $15 a month to become a sponsoring member but, you'll make far more money in the long run from being able to research tough problems. It's not for the DIY crowd. I recommend every tech especially those starting out, become a member.:thumbup:
simonb
NYC
i think it needs to go company specific for instance
honda- size 10 socket and a ratchet and you good
cruiser808
Hawaii
Access to OEM service manuals. In all my work, SST's and a fine supply of hard line tools others have identified is essential, but OEM manuals, either hard copy or online, are priceless.
walrus
Maine
Wouldn't an understanding of how what you're working works be the most important tool? Having a boat load of tools, electronics etc. won't do a thing for ya if you don't have an understanding how the thing is supposed to work. I'd say your mind is the most important tool
