oldschoolcraft
I've encountered a handful of circumstances in life where I hit a fastener, usually a Torx, that I can't turn with a 1/4" Torx bit in a bit driver, and I gave up. Not because of rust, but I'm guessing the manufacturer purposely put more torque on it than a bit driver could handle. It's also possible they red loctited it.
With Philips head, the only time they were too hard to turn was if they were rusted in.
I was watching Last Best Tool and he wanted to tighten the Torx fastener on a Tekton flex head ratcheting wrench, and his Torx driver couldn't generate the torque, and he didn't want to risk shearing his US-made Craftsman Torx driver so he gave up.
I always assumed sockets that have inserts for fasteners that are traditionally in screwdriver shape, like Philips and Torx were made for speed and efficiency purposes to use ratchets. I'm wondering if they also are for scenarios where the torque is too much than you can generate with a handle held screwdriver.
Or are cases where a screwdriver handle doesnt work are ones where you should try something else like heat or lubricating oil or drilling out the fastener with an extractor? Maybe if the fastener is torqued in so much that a screwdriver can't get it, then you're going to shear the Torx socket or ratchet head if you apply more force?
