Tools for large snap rings
Skyking1992
I need to remove a snap ring in a torque tube from a C5 Corvette. The ring is approx 6 inches in diameter. I've done it before with a large needle nose pliers. That's not the best and might be a good way to lose a finger if your not careful. The one I'm working on now is fighting me a bit and I can't seem to get the pliers to work. I found a tool on flea bay, but it seems like a lot of money for something I rarely use.
Any other ideas?
http://www.ebay.com/itm/Lang-Tools-Extra-Large-Snap-Ring-Pliers-Formerly-known-as-Hi-Tech-brand-87-New-/221570840641?hash=item3396a6b841:g:NeEAAOSw44BYIJeS[/URL]
matt_i
Best buy the tool and do it correctly. Otherwise you permanently tweak the ring into a curl, or scar up the groove, so many things can go wrong.
The big tools that I am familiar with have a ratcheting feature on the pliers so you don't have to hold it in compression the entire way.
matt_i
I forgot to mention, I really love the Knipex snap ring pliers. My favorites. I think Grrrrainger carries them amongst probably other less expensive sources.
Skyking1992
Thanks for the help guys. Just a follow up - I haven't had time to search out and order the proper tool. I've used a large long nose pliers in the past, but this one just didn't want to cooperate. Every time I tried to compress the snap ring, it would slip off the end of the pliers. I ended up heating and bending the jaws of my pliers so that they were more perpendicular to the snap ring. It was still a fight, but I was able to get it out without incident. We'll see how it goes together when the time comes. Maybe I should order the correct tool after all!
kbs2244
If you do not need professional quality, HF sell both expand and compress the ring as a set.
Skyking1992
I actually looked at the HF set today. Everything they had was for much smaller snap rings. The one I'm working on is about 7 inches in dia. I did actually use the HF long handled needle nose pliers. They are about 14 inches long and cost $10 or less. That's why I didn't mind heating and bending the jaws. If they break, I can throw them away.
619DioFan
San Diego , Ca.
Don't waste your money on the large HF snap ring pliers set. I bought them to remove a wheel bearing snap ring. they started to bend before the snap ring was half way compressed, they failed to remove the ring. Astro Pnuematic sells a 2 piece set of large size snap ring pliers that are far better.
dbabicky
NE Wisconsin
bixxjs
United Kingdom
If you don't want to buy the tool then you're going to have to pay a workshop to do the job for you.
Which is cheaper and more beneficial to you?
flat tire
hills of wv.
Astro 9402 16" Snap Ring Plier Set - 2 Piece
by Astro Pneumatic Tool
2.6 out of 5 stars
12 customer reviews
List Price: $55.40
Price: $36.83 & FREE Shipping on orders over $49. Details
You Save: $18.57 (34%)
In Stock.
Want it Thursday, Feb. 16? Order within 18 hrs 21 mins and choose One-Day Shipping at checkout. Details
Ships from and sold by Amazon.com.
amazon
• Internal/External heavy duty Circlip Pliers Set
• Features replaceable tips and spring ratchet locking mechanism to securely hold against circlip tension
• Range: Internal = 3-1/2”" to 3/8" (for 3-1/16" - 6-1/4" Snap Rings), External = 1/4" to 3-3/16” (for 3-1/2" - 6-1/2" Snap Rings)
• Length 16"" (400mm), Tip Size 0.12"" (3.0mm) - 0º 45º 90º Set
