75gmck25
Not really a garage question.
My 2 story house (750 sq ft/ floor) has a gas boiler and radiators for heat, and a ducted A/C system in the attic. It works reasonably well, but after using a tool to measure air flow I confirmed that some rooms are coming out much better than others. I've also found that cooling for the kitchen in the 1st floor has difficulty keeping up if we are using the gas range for an extended time.
- The original ducting has a square metal insulated plenum coming off the A/C unit, with flexible insulated ducts running to each room. Some of these ducts are quite long. It seems that most of the rooms have 7" ducts, regardless of the length (shortest duct is about 3 feet and the longest is about 20 feet).
- My attic has now been spray foamed as conditioned space, so I no longer need to worry about duct insulation.
- I would like to replace several of the flexible ducts with metal ducts with balance plates so I can tweak the air flow. I could also change where each duct is connected to the main plenum.
Any suggestions for tools I could use to lay out the current system and then look at the effect of tweaking the duct size and connections to optimize the flow?
For example, if I upsize the longest room duct from 7" to 9" will that help out the air flow in that room, or would I also have to connect it closer to the main A/C unit (its currently the last duct connected to the square plenum)?
Thanks for any input.
