I have a DeWalt DW059 18v 300 ft-lb impact. I'm about to do the timing belt on my Grandpa's Lexus RX300.
You guys think my DeWalt has enough beans to get the pulley bolt out with one of those Lisle heavy sockets?
Maybe breaker bar and use the starter bump method??
Don’t like doing that but when I am against the clock...
Starter bump for the win. Just do it with the car on the ground not on jackstands, it can lift it off. If you arent familiar with this, disconnect all fuel and spark fuses. Crank the engine to ensure it doesn't start. Place the strongest breaker bar/t handle you have against the floor, then bump the starter, it should break it free instantly. Very powerful impacts can do it sometimes, sometimes you need an extra heavy socket even with an impact.
Until you get a tight one and rip out a section of the flywheel teeth. I've had some of them that are definitely stronger than the flywheel.
Definitely as in you definitely think it was stronger than the flywheel teeth or you definitely ripped the flywheel teeth off? This bolt aint **** compared to the 54mm nut on a rotary engine flywheel, the actual tool to remove this gargantuan nut bolts to the engine and locks into a few flywheel teeth, ive used in excess of a 1000 real ftlbs on cheater bars to remove these before and never broke a flywheel tooth.
Obviously i try an impact first, but you gotta piss with the **** you got. If the guy is asking about a dinky electric, he probably doesnt have air or a good air impact. Like i was saying, ive had good tool truck impacts even fail to get it done while just a small bump has never failed for me. Should he go out and spend 600 bucks to get this off or use the stuff he has?
A word of caution using heat to free up the bolt. The 1MZ-FE 6-cyl engines have a 2 part construction, separated by a thin rubber ring. Getting the rubber too hot will destroy the pulley and a new OEM one is pricey.
It ended up taking cherry red heat and an 8 foot pipe on the breaker bar to pop it loose - holding the engine with the Schley tool against the vehicle frame (approximately 1200- 1600 foot lbs).
I would say the homemade one above would probably work also - the only problem might be the handle length.
