Deutschmann
They are 100% Made in Germany. Their prices reflect where they are made.
ready for streeet Luge Monty?
This is the safety self-retracting version. It cannot be locked open.
possibleAnybody know this screw extactor, is made in germany or not!!
I bought it offline from a steel manufacturer (Salzgitter). I bought sheets of 4mm steel in 2000mmx1000mm.Monte,
Where did you get the materials for the Doppelschliefbock Untergestell? The plate where the feet mount is what I am really interested in. I am looking to make one for my Doppelschleifbock.
Danke
These auctions say Made in Germany too.....no coo on stand though...Some are the same as the Compac ones. EG. AB 5 and CAX 5
http://www.compac.dk/en/products/axle-stands/axle-stands_55aa34823971c/axle-stands-detail#
Do you know where they are made ? Germany according to this dealer. Monte needs to invest.
http://www.rp-tools.at/HOESL-HEBETECHNIK
Made by Zenten in Spain i guess.The only sport you can practice in bed.
New Stahlwille arrival. Not sure who actually makes these. The blades are made in Solingen where Boker knifes are ? This is the safety self-retracting version. It cannot be locked open.
Stamped ZTN inside which presumably stands for zinc casting.
Or just not buy it.I think I would fix that not being able to lock it open real fast if it were mine.
John
Okey, thanks [emoji106] Monte[emoji1]possible
"Hunter" is a exporter of hand tools and other goods from germany. Possibly made by Schröder.
http://www.ebay.de/itm/Unterstellbo...009689?hash=item3f4c4c5199:g:~Q4AAOSwPgxVS5CJ
http://www.ebay.de/itm/Unterstellbo...599484?hash=item41a30fdabc:g:JB0AAOSwLN5WltDW
Zenten EOS Automatico: click
Also available in german "Obi" big box stores branded as "Lux".
Vikan wheel brush
OK.or buy the regular model Stahlwille 12965N
Sweet
Well done Monte. Zenten clearly have the machinery in house.
http://www.zentenbg.com/index.php/en/template-3/facilities
The company did manage to hide their name inside after all as ZTN
this thread is dangerous for everyones walletOK.
Just when I thought I could save some money along comes Monte.
only the impaktor bits are advertised for impact use...Hallo friends,
I have an inquiry about Wera's impact bits regarding if the turquoise collar bits are impact? Quite obviously their bits called Impaktor are impact capable, but not sure about the other one. I am not certain if bitorsion means impact, but they do look similar.
looks like the ancient version of the Knipex CoboltWhat's can I use this side cutter to cut ?
It's like a bolt cutter with very sharp cutting edges.
where did you purchase these?
They have 310 categories !Floor Squeegee
Probably the first time I see something that is made in Belgium on this site Probably the first time I see something that is made in Belgium on this site
Not really the coolest of tools though![]()
Snap-on ? What is that ?Just arrived,
Snap on Needle nose "Talon" grip. It seems more beefy than other pliers I have seen but still very slim at the very end.
lolMonte dreaming of Knipex mini cobra pink edition and replacing his Chinese pot-metal stands with real steel.
Just arrived,
The power of the grip is really amazing and graps everything very secure, even a hair, tested!!! What I really like is that is long but it is not bending with applied force, and the serration on the jaws is amazin.
I think knipex has a similar pattern of the serration but Stahlwille says nothing on their website. Anyone know how the Stahlwille jaws compare to Knipex?
View media item 57166
View media item 57167
View media item 57170
View media item 57169
View media item 57168
Comparison of dimensions with equivalent Stahlwille and Knipex.
View media item 57172
Lmm: 200
Handles: soft layer of grippy plastic
L3mm: 67 from the middle of the joint
Wmm: 20
Tmm: 11
Hmm: 3 (2.7 near the edge)
Bmm: 7.2 (3.65 near the edge)
Weight g: 225
Stahlwille 6534 200 mm
Lmm: 200
Head: Chrome plated
Handles: Multi-component handles with softer layers
L3mm: 76
Wmm: 16
Tmm: 10
Hmm: 3
Bmm: 2,5
Weight g: 220
Knipex 38 15 200
Pliers: chrome plated
L3: 73 mm
W: 17,5 mm
T : 9,5 mm
H: 3 mm
b: 2,5 mm
Length: 200 mm
I am waiting your comments if the Knipex or Stahlwille of Facom compare to this one. I need one more so I am tempted to get another Snapon or try something different.
the older ones (the blue ones) were spanish made iirc, the new ones look like a typically asian type jack. I think the old ones were like these.BTW. who makes those Rodcraft trolley/floor jacks, are they Italian or Asian ?
new Facom sanding blocks
<iframe width="560" height="315" src="https://www.youtube.com/embed/k7iqN00c1jU" frameborder="0" allowfullscreen></iframe>
Just arrived,
