May be not the best example. A former developer from Z+G told me, chain saw oil is the last step in the downgrading chain. That's not only true for Z+G but almost any oil maker. You could also use any oil of sufficient viscosity for that purpose.
Maybe i´ll use used car engine oil now
Ships might use something worser though
They´re made in switzerland.
Maybe the Wiha are made by PBSWISS in Switzerland[emoji4] ?
Then they´re made by Halder i guess...
It seems that these Husqvarna are the best cordless tools for the garden[emoji106]
What is the running time for the saw with one battery, approximately?
Husqvarna or Stihl
Difficult to say...depends on what you are cutting...
I cut off all the branches of a tree and there was still charge left:
I think for the hobbiest these tools are good enough. A forest worker will buy a gasoline chain saw.
I was wondering if Fein, Metabo, Festool, Mafell have any vacuum cleaner to offer like the Milwaukee one below?
If not any other cordless decent one?
Thanks!
Bosch has them in green and blue.
Hi Everyone.I am new here so be gentle
lol
I cant take a picture at the moment,but recently purchased a NOS Stahlwille stubby ring spanner "Corona series 18a" in 1/2 x 9/16. It is marked "stronger then any bolt" Can anyone tell me when Stahlwille stopped using "stronger then any bolt" ?. It feels amazing in the hand and is my first Stahlwille tool,but wont be the last!
Thanks for any help
Cheers Dave
iirc they removed the inscription in the 60´s. I think the reason was easier forging.
Chain Saw Oil
I remember reading somewhere that all European bar oils are non-petroleum based--that is, they are vegetable oils.
You can get 2 types over here. The standard mineral oil based oil and the "Bio"-oil often based on rapeseed oil. The forestry office usually requires to use bio oil. The bio oil will disintegrate > 60 % within 28 days.
1. Is it better to have more power output above 600W or lower weight?
2. Is the speed very important, i.e. above 8-9k rpm?
3. Is paddle (dead man) switch required?
4. Does anyone knows the difference in FEIN Blocking monitoring vs kickback stop?
1. More power = more weight. Depends on your application...A slim light tool for single hand use is good for deburring for example, but for grinding down thicker stick electrode welds you want something with more power and most likely use two hands. The best is to have both
For example a slim entry level grinder from Makita or Bosch for example and a more powerful model with >600 watt output and ideally constant electronics. (or better yet around 1000 watt output...)
2. The abrasive grain in cutting discs and grinding wheels works best with high speeds (~11.000rpm). However flap discs and other abrasives can be used or must be used with lower speeds (SC-discs, Scotch-Bright, non-woven discs)
3. no
4. I think it´s about the same. A speed sensor located at the rotor measures the rpm. If the speed suddenly slows down the electronics shut down the motor.
Only Metabo (?) has a safety clutch which disengages when the disc gets stuck, while the motor keeps spinning.
Does anyone know about this torque wrench? Found it in my dads basement, it's about 20 years old I think.
Probably one of the best torque wrenches made. Made out of one solid piece of aluminium.
Hi guys,
If I remember correctly in this thread, I think Monte stated that the Fein 1/2" impact wrenches are the same as Milwaukee, although with a different body design. Please correct me if I am wrong.
If it is like that can I use the Fein batteries for my Milwaukee tools?
Kind regards
The old Fein impacts, yes. The new ones are made here. The batteries are different though
Hi Monte.
The PMA sucrion cups look almost identical to some of them made
By Piher. Likely to be all rebranded from Veribor ?
Rebranded or copied
Look out for the coo
Hi,
What is your opinion about this Beta set?
https://www.tool-net.co.uk/p-430209/beta-2047-e-c108-108-piece-tool-kit.html
Here, it will be available for $ 250. It should not be Italy made! Another option is the Toptul for $ 220. My friend is going to buy for personal repairs.
Thanks.
108 parts for 250.- ... Taiwan...?...
An old AEG jigsaw with no coo, not common at that time, maybe the first ones not made in Germany; who knows.
AEG bought certain tools from Sparky/Bulgaria in the past.
Oregon grease press
