upgrading
Nice pics of Toom
Knipex also has some nice plated pliersNice Monte.
Finish on the cutters looks similar to the Made in Switzerland Wiha's I have.
Felo 373 bit driver. Bit storage pops out on a spring when the cap is unscrewed. Cap 'Klicks' shut so feels like it will stay closed in use though I've seen some comments saying that it opens sometimes. Handle has a relatively large diameter.
Not sure how much I like it either. The clear part definitely has a cheap plastic feel to it and the internal mechanism rattles. You can both hear and feel it knocking around inside when you use the driver. Removing and replacing bits in the holder is a little fiddly.
It's cheap though.
I purchased from here if anyone in the UK is looking for one.
https://www.ebay.co.uk/itm/FELO-BIT...036162&hash=item1a11b916d2:g:PXQAAOSwJQdXC9PT
I've been looking at that for months but haven't pulled the trigger on it. Not sure if I'll like or dislike the pop up.
Is it real? I've only seen them in Red.
The ones in Red also have a Red plastic top.
It's cheap though.
It's not as nice as the PB Swiss ratcheting screwdriver's bitholder, but mine has never popped up unintentionally in use. It could be much worse, such as Snapon's curiously under-designed ratcheting screwdriver's bitholder.
Nice posts/tools JBH.
Will definitely be picking up a Wera bit case some time. I see on an Amazon.de review that it can also hold power bits.
Made a vid on the Felo 373 bit driver. Not brave enough to talk so you get me breathing for 2 mins.![]()
<iframe width="560" height="315" src="https://www.youtube.com/embed/WHyp0QgX_Zw" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
You figured out that the bitholder comes out right away!?!
It took me a few weeks at least to get there.
They do look a bit nicer.....maybe next timeWherever they're made, they feel a bit nicer to me than the Lessman hand brushes. The brush wires aren't as splayed right out of the package, they're about 30g heavier, at 130g vs 100g for the Lessman, and the handles have more rounded edges which make them more comfortable to grip. Haven't had much chance to compare them in actual use or longevity yet since both sets are pretty new to me.
.[/QUOTE]:thumbup::pimpflash
[img]https://up.picr.de/37462454mo.jpg
The ebay ad had a pic with the bit holder pulled out. Don't think I would have figured it out myself.
The bits are visible thru' the cap and the green ring has "CLOSE" with an arrow on it................................................
That’s the bit storage, not the bitholder![]()
...I will say the collet, while impeccably machined and finished like jewelry, does not grip the 3.5mm shaft as well as 4mm Felo or Engineer handles grip 4mm shafts. Don’t push down too hard on it! A ball detent system (e.g. Wiha System 4) is better design.
PB Swiss shafts are 3.5mm, so handle and shafts are incompatible with standard 4mm micro shafts.
I thought the short nose ratchet screwdriver would just be an extra tube on the end of the short nose, but actually they’re fairly different.
I thought they would be the same as a set of little Orbis combis I use quite a bit, except with better handles. They are not. The jaws are quite a bit thicker, more like the Tsunoda mini-combis.
Those Orbis pliers look interesting. I see they were made in W Germany. Are they long gone or still available as old stock?
How do you like the one from Tsunoda? I have some saved in my Amazon cart but haven't previously used anything from the brand.
Nice, your guess is correct, I looked for those here in the US but most of the FM Stanley seems to be Taiwan
Think the pliers are made by Bost....but Stanley owns Facom who owns Bost so same difference.
OK Quality DIY tools...Monte: What do you think of Wolfcraft as a brand?
