Tools Where Air Power is Still Relevant
dr_clyde
Holland, MI
Some Amish only use air tools. Was just at a sharpening shop where everything was air powered. Bench grinders, sanders, even a winch for lifting the heavier reel mowers were all air powered. I'll have to post pics when I get home.
I mean, that argument pretty much is only relevant to the Amish. They use air to get around restrictions in their religious beliefs, not because it’s the best way of doing business.
rlitman
Long Island
I have two pneumatic chain hoists, and they totally kick the pants of electric hoists. Pneumatic is inherently variable speed.
VolvoRyan
Kentuckiana, USA
How are they compressing air? Just curious. We live in Amish country. While I applaud them for being able to live that lifestyle, they have a lot of workarounds.
-Ryan
Odd-job
where do they source the compressed air from?
edit: sorry am curious like VolvoRyan^
dr_clyde
Holland, MI
Engine drive compressors AFAIK. I’m not Amish lol.
From what I understand they are more interested in not being connected to the grid/system and they’re ok with certain advancements if it allows them to live their way more than not.
dscheidt
True, and I wonder why. Milwaukee has figured out everything except coil nailers. What's so special about these that nobody has come up with a cordless solution. From the safety standpoint alone (no air hoses to trip over leading to falling off the roof) cordless roofing nailers would be a great advance.
Cycle time. coil nailers are used to shoot lots of nails fast. Cordless nailers are slow. For most usage, that doesn't matter, because the time to place the nailgun is longer than the cycle time. That's not true with nailing down sheet goods on the roof or wall, and it's not true of shingles either. If the tool makes you wait, it's not good enough.
neophyte
Pennsylvannia
I totally forgot about the dentist. I don't see battery powered tools landing there anytime soon.
There are Foredom flex shaft grinders sold for dentistry, although mostly for use with farm animals.
Foredom also makes a line of micromotor tools, which look larger than dental drolls, but probably still useable.
mogandave
Bangkok
Are they wet or dry? I can't imagine having to go back to having a dry drill in my mouth.
RedneckWelder
The Ghetto Kingdom of Methlandia
Cordless tools would probably get replaced every 3-6 months if not sooner doing transmission repairs. From getting oil/solvent soaked to the rubber bits swelling up it's just not feasible. I wish I could lose the hose but the environment dictates what tools I use not to mention the air used cleaning and testing.
I have, use and love cordless tools but they will never compare to the durability of air tools.
Air shines in the muck. I can wash my air impacts off in the parts washer without issue so long as I don’t drown the exhaust and intake.
The high torque impacts still aren’t as good as a modern 1/2” air impact power wise and tend to be much heavier. Don’t get me wrong the battery impact is great for working away from air or just zipping a couple bolts but for real repetitive work air is where it’s at.
3/4” and 1” impacts are still best with air. We had a new guy come in with a Milwaukee 3/4 impact which is a slightly hopped up version of their 1/2” high torque. First time he tried to do a dozer undercarriage with it he didn’t get past more than a few bolts before he needed to borrow an air gun. The Milwaukee tripped overheat protection constantly.
Die grinders are best in air. The battery ones are nice for a quick cleaning of something but they eat batteries for sustained use.
D
dnschmidt
Phoenix, AZ
It all depends on the work being done. For most automotive cordless impacts can do just about everything an air impact can. If they can remove a Honda crank bolt, and they have demonstrated that they can, that's just about the hardest job in automotive repair. The only advantage of an air impact in automotive today is the truly compact tools like the Astro Nano Version 2 and the SPAir impacting ratchets which are very small. In any modern automotive application space is at a premium.
RedneckWelder you mentioned muck and bulldozers. Few automotive shops work on dozers or have dirt floors so that precondition doesn't apply. HOWEVER, if heavy equipment is what you do for a living there is little doubt that air is where it's at for exactly the reasons you've mentioned. HORSES FOR COURSES IS AN OLD STATEMENT BUT ENTIRELY TRUE.
jpaw
While in most cases they "can" get the job done. My question is when there is air available to you is it really the best tool for the job in a production based environment?
My answer at this point is still no.
The cost overhead in the long run is still going to be higher for cordless tools when you account for longevity and batteries in most cases. Air is still needed for a lot of things in the automotive industry so you will still need a rather capable compressor unless you want another throwaway tool...
While I won't argue that cordless tools are great for most interior work and some mechanical work it will be awhile before they unseat air tools in a professional setting where air is provided.
Back to the original question of "can". Just a quick example. Can I rotate tires with my 3/8 air impact? Yes. Sould I? No. Why would I abuse my 3/8 gun and waste time when there is a easier way to get the job done?
There is nothing worse in a shop than listening to someone repeatedly hammering on something to get it apart. Whether it be with a hammer, impact or god forbid an air hammer. So when someone pulls out the cordless impact and hammers away on the "Honda crank bolt" it comes back to "can or should". My air gun will make quick work of it.
For home garages cordless is a game changer and in a lot of ways it has been for the professional but, it is not a replacement for air rather just another tool in the box.
strutaeng
Dallas, TX
Yeah, battery cordless is nice. But I think for heavy duty or continuous duty use, pneumatic is better.
Spray painting, needle scaler and die grinder are the ones I use often that are exclusive pneumatic.
country83
-Ryan
The place I visited used a Deutz air cooled diesel with a belt driven compressor filling some old I think 500ish gallon propane tanks. He had a timer set for 30 minutes, it would start, run for 30 minutes to fill the tanks and then shut off. Then he could work for a while before having to restart the motor.
Motor was electric start, go figure lol.
country83
My dentist here a couple weeks ago used a battery tool for the cleaning. Now, as for drilling for fillings, I dunno, I'll find out in a couple weeks.
dr_clyde
Holland, MI
I think this is the classic thinking of black and white. It’s as though people think if you have cordless you can’t have air or corded.
You can have both.
I tend to buy a corded tool first then if I use it often enough to warrant a cordless I buy it.
But I don’t think I own a cordless tool that I don’t have a corded version of.
neophyte
Pennsylvannia
I presume the micromotor units would have to be used dry.
The flex shaft units could be used wet, but I gave no clue how they’re typically used for animal dentistry.
The big win for pneumatic tools is that they can usually be easily and cheaply rebuilt.
When a battery impact get weak, throw it away.
Sumboodie
AK
My tools. I would like to have battery powered stuff but I simply can't afford any at this time. And now I gotta come up with $50k to drill a new well. I don't see any battery powered tools in my near future. I already own air ones.
50k buys a ton of hauled in water...
We have a 3000 gallon tank at work, lasts 5-6 months with toilet, sink and occasional floor and truck washing.
Costs about $300 to fill and that's BFE AK price, so probably 1/2 that in the lesser 48.
xjfish
I still bust out my air ratchets to drop a messy transmission pan or anything along those lines. Most of my personal other uses have been covered. Electric tools don't like to take ATF or coolant baths.
PoorUB
Fargo, ND
I bought a HF air ratchet many years ago. One day I grabbed it and it wouldn't spin, locked up. I took it a part and found one bearing rusted up. I guess I didn't oil it often enough. I fiddled with the bearing and got it to spin and blew it out good. Put a couple drops of oil on the bearing and reassembled it. That was probably 10 years ago and the rusty bearing is still rolling along!
