Tools you always had but never used
sparky 1971
Central Iowa
I have many, but at the top of the list is my Mac 1/2" drive, 26" locking flex head ratchet that I bought over a year ago. I just had to have it, was working for a Mac dealer, he told me $200 cash and it was mine and so it was. I didn't think about the fact that I had never used my 24" Gearwrench locking flex, so now they sit side by side. At least the Gearwrench was cheap, even after the Matco guts went into it.
PFSard
Mesa, AZ
For me it's vise grips. I probably use vise grips once a decade. I think I usually cut or grind it if I can't turn it. But way early on in my pre teen wrenching years everyone had a pair so I bought mine from Bradlees and added it to my collection.
- Bradlees. Now that's a name I had forgotten. What brand Vise Grips? Peterson, I presume.
- And to answer the Title's question. Kind of (not always had). The large collection I've bought (mainly at garage and estate sales) since finding this Web Site.
dwasifar
I assume you mean regular normal tools, and not fad gimmick tools.
Someone gave me a Hitachi oscilloscope once, and I never used it in the 10 years I had it. Don't know if that qualifies.
If you just mean hand tools, I can't think of anything I've literally never used, but my SAE open end wrenches and slotted screwdrivers don't get a whole lot of use. With the wrenches I only need them for brake lines and fuel fittings, and it's been ages since I had a non-metric car. For household work like water lines, I generally use a crescent wrench. And the slotted screwdrivers only come out for guns and old radios. So it's not like I never ever use them, but it's pretty seldom.
Ohmthis
Outside of Louisville KY
I’ve used almost everything people have posted in just the last two days. That is not just at work (industrial maintenance), but at home. I have a vacuum brake bleeder that I’ve used exactly once. The worse part that it only worked ok. It does make the process of flushing brake fluid faster, but I still had to pedal bleed to get a hard pedal.
bsaint
Manchester, CT
I use adjustable wrenches a lot in hydraulics but I can see auto and truck mechanics not using them so much. Also if I worked of rusted stuff more I Def would use them. I don't remember the brand vise grips I was about 13 or so lol. Now my vise grips are Facom.
Tools4Me
I have a couple specialty pullers I purchased from garage sales. I have yet to use them, but you never know right?
The only other tools I can think of are my drag link sockets. 8-10 of them, purchased here and there from garage sales. I know if I get rid of them I will eventually regret it, but they always seem to have blades that are too thick for any alternate use I try them for.
My 6pt wrenches get used quite regularly, but I can't recall any situations where a 6pt was necessary for the job. I could probably sell them off and be perfectly fine with my regular 12pt combo wrench selection.
Meursault74
Southern California
1/2 in drive SAE sockets. They came with the Craftsman set (1/4 and 3/8, SAE and Metric . 1/2 drive SAE) I bought in the early 90's, I think I might have used some of them just to use them at one point, but the 3/8 in drive SAE would have been appropriate for my needs.
gatewaysysop
Arizona
Probably my first choice for this would be a pair of Pozidriv stubby screwdrivers (Wera branded, I believe) that I picked up in Europe while on vacation. Close second is probably 1/4" breaker bar that likely came with a socket set ages ago.
f121
UK
My snap on low profile 3/8 sockets and ratchets. It's a lovely set, beautifully made but pretty much unused...if access is tight enough to need it, I go for a wrench. I think I've used the 10mm twice as a hex bit holder for really awkward access on a VW.
matt_i
I bought a Tree tapered boring head and have never used it in ~20 years of ownership. It also occurs to me that it resides in the drawer with a weed burner torch that I've also never used.......
tyyost
Tunkhannock, PA
For me it’s crowsfoot wrenches. I just haven’t found anything they would do for me another tool wouldn’t. I know some use them often, so I’m either not seeing the opportunity or working on things they aren’t needed for.
FMB4
Offset ratcheting wrench set. Been sitting in my odds and ends duplicate/triplicate tool box for years. Don't even remember if they're SAE or Met. Guess I'll have to look the next time I'm in it.
seber
Deep East Tx.
Ratcheting wrenches were in the box for maybe twenty years without being used even once. Also two stud pullers. I don't think I have every used them either.
unslow1
Illinois
I have a Branick G300 brake bleeder that has never had fluid in it. Then the same crow's feet and pass thru sockets as many others. Gimble ratchets, a few other vacuum brake bleeders, CV pullers and I'm sure I have more because I have a lot of specialty tools. I often buy them after I've been in a jam and really needed them.
Bessy
Ontario, Canada
For me it was the long (I think 18, 24 and 30 inch) 3/8 drive extensions. I needed a long one for removing the battery in my Mother's VW, once, bought the set because it was the only option at Crappy Tire and I didn't feel the need to wait for Amazon (this was several years ago, so they didn't have stellar shipping time in my area). Since then they have hung on the side of my box untouched, keeping in mind that I am a weekend warrior, not a pro.
Ratcheting extractor "wrenches" I have used once or twice (It worked so now of course I want the ones that go on an impact just to have them for a pinch), but by far the biggest disappointment in my toolbox is the sets of universal spline wrenches and sockets. Again, they're for those special cases that seem to never come along (like e-torx). Maybe I'm just not taking on any majorly challenging tasks, which is a distinct possibility.
Davefr
OR
Some of my least used tools have been the ones that saved my *** like a handheld impact driver. The one common tool that stands out as rarely used is a ratcheting screwdriver. Some guys always use them but I'm just in the habit of grabbing regular screwdrivers or grabbing a cordless driver.
Zewnten
hand held impact driver. Used it 16 years ago doing a brake job and then used it the other day to remove a roof on a loader.
