Top flange bolt?
tomtomgt356
*******, GA
Hello! I got a message from a coworker that has us stumped. He had to cut off a bolt and is trying to find a replacement but we can't figure out what its called to find one. Its like a carriage bolt or elevator bolt but has a hex neck. Its flange-hex-threads. Below are pictures of the flange portion of the bolt as well as where it goes. It comes up from the bottom with the hex in the opening and the flange holding it in place so you can bolt the next piece down.
Any ideas on what this would be called?
Dumber than lumber
That somewhat resembles an elevator bolt. But judging from that heavy metal component I am guessing it is not some Ace Hardware off-the-shelf part. Who made the machine/attachment from which it was removed?
Also, did you check McMaster Carr?
PCustoms
VT
What does it go to?
That hole is hexagonal?
I'm guessing it got disassembled wrong (hence the cutting) and that's some sort of press in PEM stud
