My order arrived a week or 2 ago. Finally, here are the pics. The cherries have been popped, no new out of the box glamour shots here... (Merk, continue at your own risk...)
Needed a little stubby P1. Works great. Handle is comfy. Nice thumb rests and palm swells. Green is hard, black is soft. Conformable to the hand under pressure/squeezing, tough enough so you can't feel the handle twisting around the shank, just enough tack with hand-sweat to stick to the hand and not slip. Much better handle than the Craftsman black & red pro drivers (I have 21 of them). I think I'll be buying some more...
Ad-hoc durability test on the grips. Squeeze like heck with a nail to make indentations.
About 60-75 seconds later, the indentations are gone.
Typical finish. Bad light in the garage, others have better pics.
Cover plate fits just a little loose, which is fine. The plates on my Ferrets are so tight - even tighter than S&W revolver side-plates. Tight enough and enough contact area for a good seal - loose enough for simple servicing. Excellent. 3/8" drive socket in the back for support.
Even the lube is green!
Works great. Went out and busted some nuts loose on the backhoe. Ratchet just yawned.
THIS is a well-made pair of pliers! I own about a dozen pairs of dikes. To me, they're the "can you make a pair of pliers" item. These are NICE. Grips are soft enough without being overmolded ricer-looking trash. Black oxide finish is superb. Sanding of tips excellent. No need to Kroil these out of the box - full range of motion with no sticking or binding. Nicer than all my Knipex dikes.
Perfect alignment and cutter facing.
After about 100 cuts of 12-2 and 14-2 wire scraps, cutters still look new...
