Toro 20374 pinion gear seized
trooper1954
Salmon Arm, BC, Canada
Hi all,
Have a different issue from my mikuni carb.....cannot get the pinion gear off the end of the drive axle on the above mower......copious amounts of Deep Creep penetrant over 3 days, and also heat from a torch to almost red hot.....still won"t come off!!! And in trying to pry it off I've destroyed the plastic washer that sits behind it, so in order to repair both, the pinion gear has to come off!!!
Any other suggestions greatly appreciated.
BillK
Beautiful Southern Maryland
Thanks BillK.. yes I removed the retaining clip.
Photos to follow.
We ended up holding his in the air by hand and whacking it with a hammer. We turned it on its side and he pulled up on the plate that the drive goes through and I smacked it a few times until it came off. This is probably the third time he has has to fix his but he is cutting lawns as a sideline so it is getting a lot of use.
BillK
Ok, that is totally different than the one I was working on. Depending on how big the gear is a pitman arm puller might work:
If a new gear is easily available then you might just have to cut it off. Make a groove down in the valley of one of the teeth and then smack it with a sharp chisel and the gear will split.
Fixr
SW VA
I have seen shafts get mushroomed a bit at the end from removal attempts. That one appears to have hammer marks, so it could be mushroomed.. Sometimes pushing the gear down on the shaft and filing the end of the shaft will allow the gear to be pulled off. And I agree, use a gear separator, plus heat if it's still stubborn.
T
trooper1954
Hi guys.....quick update....
Bearing separator arrived yesterday, and pinion gear is on its way out!! Only problem was the drive screw in the center that actually does the pulling even tho pointy, was a little bit too wide for the rectangular hole in the end of the gear. I think I'll just file it down for now, or look for a bolt with the same thread and file it instead.
One other question....in trying to remove the gear before I got the separator, I destroyed what appears to be either a fibre or plastic washer on the drive shaft on the inside. I've looked at numerous parts diagrams of this transmission system but none show this washer....any ideas what its called and how I would order a new one?
Have included a picture of the other side.
Mower is a Toro 20055 serial # 250008366
Thanks
PCustoms
VT
Thanks
I don't see a fiber washer:
There's this:
