LPCapital
Part of the timing procedure on a car I'll be working on requires to replace the hydraulic chain tensioner with a static one which needs to preloaded at 0.7Nm or 6 in lbs.
I found a torque screw driver that will allow me to be in that range:
The room around the area is too tight and the handle of the screw driver won't fit. I know u-joints cannot be used with torque setting tools because they affect the arm, thus change to torque, but will a flexible drive have a similar effect or such an extension will be torque neutral?
Here's the one I'm looking at:
