Torque Screwdriver
LSU
Any recommendations?
5 ftlbs is what I need to measure.
Lower unit oil Drain screw on an outboard Motor. Flat head screw.
Will use the tool about once a year.
Suggestions?
Jland
Colorado
Those things actually exist?? Being serious here... isn’t 5 ft/lbs about what a 3 yo can tighten to??? Finger tight maybe??
Gunfixr
behind the house
Wheeler makes an inch/lb 1/4" drive torque driver, that's like a screwdriver. Times 12 is ft/lbs. It goes to 60 or 80 inch/lbs. It's aimed at gunsmithing work, but measurements are measurements............
McGR
Illinois
I've been changing l-u gear oil for many years. I've never used a torque wrench/screwdriver on these. I usually just use a large square shank Craftsman screwdriver with an adjustable wrench and make it extra bubba tight so it doesn't leak. Most of the time I'll replace the nylon gasket/washer too.
2ndGearRubber
Pittsburgh
That's 60 in/lbs. A 1/4 torque wrench and a flathead bit in 1/4 drive would work. Most 1/4 drive inch/pound wrenches go on a scale starting from 20 to 150 or 200 in/lb. A word of advice with low torque value fasteners oh, the click of the torque wrench or screwdriver can be fairly subtle, this is especially bad on cheap 1/4 Drive torque wrenches. Torque screwdrivers are typically a bit more positive in that regard
bob15
Northeasten, CT
This is why I like using beam or dial torque wrenches in these low torgue applications. I used a 0-30 in/lb dial wrench daily at my previous job to torque two terminal studs to 12-16 in/lbs and 4 screws to 21-25 in/lbs.
L
LSU
Seekonk looks nice but $$$.
in the past I’ve used a hollow ground flat blade screwdriver with great success.
bob15
Northeasten, CT
You pay for what you get. You want a precise instrument or something that gives questionable torque numbers?
And they aren't any more expensive that CDI, Snappy, S-R or proto.....
Balor
Florida
I use a Snap-on screw driver torque wrench Qdriver2 5-40 inch lbs and works great
macgee
Sepulveda Pass, CA
I really like Felo's version. They accept regular 1/4" shafts (long). Easy to change settings and feels like a really good (normal) screwdriver. They also sell a really nice HD hex bit holder for it and a nice 1/4" square for sockets or you can use one that you may have lying around.
they come three sizes. On sale here: https://carbideprocessors.com/torque-limiting-handle-5-13-in-lbs-felo-52149/
I also own Wiha versions but meh; as they need proprietary shafts (pricey) but they have play/slop and their #2 PH Phillips bit for them is defective (undersized) but you don't need to worry about that. I much prefer the Felo and they’re less expensive.
I also have a couple of Utica's, usa made and really nice. Pricey but you can find a bunch of them on eBay for low prices. Just make sure you get an adjustable setting "TS 30 or 35" version; can be had for around $35+. Also need to keep an eye on the tip type as they vary.
https://www.ebay.com/sch/i.html?_from=R40&_nkw=UTICA+Torque+Screwdriver&_sacat=0&_sop=15
