Wobbling the truck must have pulled the anchors up a small amount. I was able to get another 1/4 turn or so almost all the bolts before hitting 90 ft. lbs.
I haven't had time to lift the truck again, but I am pretty confident that was my issue.
Also, in my brain, tightening to 150 then loosening the nut makes sense. That would expand the bell and really seat the anchor in place. Once the anchor is set, you can tighten the clamp load on the base plate to what ever spec you are looking for.
I found the spec in the manual, it's under the maintenance section in the back, not in the installation area. The spec they list is as jimp describes, 100-150 ft. lbs.
