Torque Wrench Adapters
tommydog35
What do people think of this (Motion Pro Adjustable Torque Adapter) which can be used with any wrench you want - Is this a good option or are there better alternatives?
T
tommydog35
Interesting. A cheaper alternative to using crowsfoot wrenches for the same thing?
But you don't always have the room to get above a crows foot to torque it. I Know you can get special torque wrenchs for use with crows foot like these:
But these tend to be much more expensive than the torque wrench adapter at the start of my post.
Bondo
Greenfield, Maine
Ayuh,... That thing will alter the torque factor, ya gotta recalculate where to set the torque wrench to get where ya wanta be,....
In yer picture, 'n 'bout an inch, 'n 1/2,....
T
tommydog35
I found some instructiojns which say about this and they tell you how to recalculate. But they say If you mount the wrench at a 90 degree angle to the handle of the torque wrench no calculations or adjustments to the specified torque value are required. Here are the instructions:
Banshee365
I think if you're 90 degrees off the crowfoot/wrench your torque will translate accurately.
rlitman
Long Island
Exactly.
How would this adapter give you more room than a crows foot? Because it allows the torque wrench to be further offset? But now you've got two wrenches at 90 degrees to each other to contend with.
The wrench adapters are a totally different beast. Unlike the crows foot, which must be used at 90 degrees, a torque wrench open wrench adapter is designed to be used straight on. THAT certainly improves access in many cases I can think of.
T
tommydog35
I agree, any any recommendations for a good set? I would like metric heads with a flared design to get on fuel lines. Main priority now is something in 14mm. I must be able to use it straight on.
crewchief888
NW indiana
just scratching my head, but what about a line socket?
mine are all SO...
:beer:
crewchief888
NW indiana
i was thinking more on the lines of this...
Socket, Metric, Flare Nut, 14 mm, 6-Point
0 stars
49.75 USD
Item: FRXM14
sorry cant get the pic to load :sad:
:beer:
drewvdw
Central Illinois
I gotta ask, why are you torquing fuel lines? I've always had good luck with the good old German torque spec of Güttentite with all sorts of hydraulic, gas, and diesel lines. And if it leaks, you didn't tighten it enough or the o-ring is shot.
