AdamMopar
I'm going to go ahead an disagree again.
An inline shaft cannot absorb torque. It can twist, but it does not matter.
The simple virtue that a fastener is moving does not affect anything in this problem, so long as there is no acceleration. The coefficients of friction (mu's) will be kinetic, instead of static. This is the reason a fastener is supposed to be rotating prior to the torque wrench clicking/beeping/lighting up etc.
The twist does not necessarily mean that there IS an imbalance of forces, it only means that there WAS. When the extension reaches equilibrium, the imbalance is gone, and the torque applied is the same as the reaction force at the socket. If this were not the case the extension would continue to twist and would end up looking like a pretzel.
The only way I could see an long extension causing any sort of discrepancy is if it was not kept perpendicular to the workpiece. Like this: Credit to THEO on this pic.
All of the major torque wrench manufacturers I have come across suggest that correction factors must be used ONLY for extensions to the length of the wrench itself.
EX:
http://www.cditorque.com/main.html
I could be wrong Elroy, but I don't see where. Lemme know![]()
You are correct.
