gayler
Anyone here doing this at home like this guy?
Im not saying this guys $5 scale is accurate. If you had an accurate scale is this a useable method?
I'll add that the problem with calibrating a torque wrench isn't applying a known load. It's knowing how to adjust the wrench when it turns out to be inaccurate. If you have a wrench with an adjustment feature like the one in the video, that's easy. Other wrenches that I have require some disassembly to get to the adjustment feature. How they come apart isn't always clear.
It would be better if the scale were of known accuracy AND if it could capture the peak weight. Sometimes digital scales are fairly slow responding and the reading you *thought* you saw was actually lagging behind and is too low.
The digital torque adapter at HF ($30) is a way better comparison.
Ok, how do you do it?
Guessing either an manual or automatic torque loader with a digital torque analyzer.
