Torque Wrench: Ideal use?
shellback
Jax, FL
Hi folks,
Did a quick search and seems like its for precision type work. Could someone please chime in what type of precision work I would run into at home or general car DIY projects?
Its been laying around and don't know if I have the need for this.
Thanks for the help.
Skyline
There's lots of things on modern cars require inch/lb torque wrenches; some more sensitive than this.
Skin
Boston
Fairly certain spark plugs are around 200-250 inch pounds, same for small engine head bolts. Below that is fairly useless honestly.
NiteWolf
Vancouver, WA
A 2003 Dodge Neon spark plug spec is 156 in-lbs and 2000 Ford Focus is 108 in-lbs; just saying.
But in all truth I have never used a torque wrench on a spark plug.
mypov
wheel lug nuts - unfortunately not enough techs use these, I just do not trust those damn torque sticks.
Skin
Boston
I have, found most (modern crush washer type) are pretty dead on at about 180 degrees from the stop point of hand threading so I don't bother anymore either.
OPs torque wrench is up to 150 INCH pounds, not foot pounds. Definitely don't want to use that on lug nuts :).
Torque sticks do have their places for areas other than wheels too. For example a crank bolt if you don't have the special tool to hold the pulley in place for a torque wrench. Something is better than nothing whether you trust them or not. Good tool to have in the box.
dsmnickk90
Valve covers. Some cars have brittle cast aluminum valve cover that are to be torqued to 4-5ft/lbs and any more than that they will crack.
TPS sensors are another place.
General Geoff
Allentown, Pennsylvania
Yeah, the torque spec for my old BMW's valve cover nuts is 8 ft-lbs, or 96 inch-pounds. The torque spec for the oil pan, timing chain cover and distributor block are similar.
tsonka
When I was a tech I used my inch /lb wrench all the time. Repair that took any amount of disassembly to access the part, only takes a moment to look up the torque spec.
Steinmetz
Washington State
I use smaller torque wrenches all the time for a variety of tasks.
I recently used a torque screwdriver to reassemble a carb on one of my vintage cars after a rebuild.
Steinmetz
Washington State
Hi folks,
Seekonk is a good brand, BTW. Hold onto it.
djkeev
North Western New Jersey
Dang! Why do people end up with tools when they haven't a clue of its purpose?
Put it in a box, mail it to me, I'll give it a good productive life!
Dave
bob15
Northeasten, CT
I have lots of uses for it: chainsaws, snowmobiles, antique farm tractors, etc
If you don't need/want it, drop me a line......
bob
ToocoolZ28
Mid Tenn
I needed one of those for a job I was in the middle of and had trouble finding one. I now use it about 2-3 times a month setting up rear ends.
jebutler
California
Those type are great for ****** valve bodies and under pan components having slightly different torque values. No re-adjusting setting just pull to correct torque.
P_I_Torque
Nice looking torque wrench there. Dial type... my personal favorite style. Enjoy :)
BobKovacs
The newer GM engines have several bolts that have torque specs in inch-pounds, including two long, spindly bolts at the back of the oil pan that have been know to snap rather easily when the assembler applies the same 18 ft-lbs of torque to them that the rest of the oil pan bolts get torqued to.
