I know this is probably going to be a rather simple question with a rudimentary answer, but I figure I will go ahead and ask anyway. For my birthday I got the Gearwrench 3/8 digital torque wrench, which is specked to 100 foot/ pounds. As a test of the wrench I decided to torque down my lug nuts. The Acura specifies that the lug nuts on my RL should be torqued to 95 pounds.
So with that in mind I set off to test my new torque wrench. When I torqued the lug nuts to 95 foot pounds it did not feel as if the lug nuts were securely attached. When for testing purposes I proceeded to use the torque wrench to remove the lug nuts I just torqued down, and noticed that the pressure indicator was all over the board with values ranging between 50 and 70 foot pounds.
What am I missing here? Can I use the torque wrench to test the torque values by removing a lug nut with the torque wrench?
Yes, I did read the manual. Three times in fact. Also, I did not use the torque wrench as a breaker bar to originally remove the lug nuts.
Thanks!
http://www.garagejournal.com/forum/images/smilies/twitch.gif
Thanks!
