Torque wrench set below lowest setting will it do harm?
toolaholic
PA
I was setting my harbor freight 1/2 drive torque wrench to it's lowest setting which is 10 to store it in it's case. The knob was a bit stiff and the wrench went well below 10 and you could feel the tension leave the adjusting ring. I quickly set it back to 10. I tested it at 40,50, and 70 left w/ the all trade torque adapter and it spec'd out ok. Will this hurt wrenches if they briefly fall below lowest setting?
jeffk14
GA
I don't think so. All I've ever heard is that they should be stored right at the lower end of the range, not with the tension completely released from the spring. I think you're fine.
Kracin
Omaha, NE
only time it could cause a problem is if it went so far below that there was zero tension on the innards of the wrench, causing something like the pawl or a ball bearing to fall out of place. most (not sure if any arent) wrenches when at the lowest setting should still have a small amount of tension. if you have ever tore a torque wrench down you'll see that it needs to be compressed about a 1/4 to 1/2 inch when putting the top half in before locking it in place.
Zeke
I really never knew all the tips and tricks for a torque wrench. I damn near ruined a Craftsman 3/8 drive TW by unscrewing it too far. AFAIC, the design was poor in that it let me unscrew the innards. I got it back together and re-calibrated it to the best I could with other tools and weights that I had.
AFA the HF 1/2" that I have, It's never given me a problem releasing all of the tension. I guess there's no need for me to change my ways now. :D
And I won't ever buy a Craftsman TW again. Mine is old enough to be "made in the USA" but I think it's a POS.
SMKS
USA, planet Earth
I think the concern is more that on some designs you'll unscrew the handle and/or mechanism and things could come apart.
I would not be concerned, especially since you already checked it and know it's still working properly.
cheechi
Triad, NC
I've worked with guys who release the tension all the way when they store them. Never had an issue with them being out of spec. I see other guys from time to time that don't release the tension all the way. And they don't have issues with going too far out of spec either.
When I worked in a heavy equipment factory they ran 2 shifts and the wrenches were just set to spec all the time, tested every Friday. They still have them but now they use go/no go for most of it.
I personally prefer the beam type but I have a HF clicker type. It might be set as high as 10 ft-lb right now. I barely use it.The other thread just like this pretty much has the same mix of answers
ctb
Central Europe
Had a Gray torque wrench that I unscrewed too far and couldn't get tension on it after. Took it back to the place I bought it and they warrantied it. Pretty nice of them I thought. Now I leave it at 10 Ibs or so.
P_I_Torque
This is the largest concern. Without a positive stop on the bottom, one could simply disassemble the torque wrench. Equally important, and remarkably very rare in present day torque wrench manufacturing, is a positive stop at the top to not over tighten and damage the internal components.
