I had Harbor Freight 3/8" 5~80 ft-lb torque wrench for over 10 years. It's not working anymore due to rust. I brought it to Harbor Freight, they simply gave me a new one as "life time warranty" replacement.
The following are the results, comparing against a Powerbuilt digital torque adapter:
Torque setting (ft-lb) Reading #1 Reading #2 Reading #3
10 ==============> 9.8 10.5 10.7
20 ==============> 19.3 20.6 19.7
30 ==============> 29.2 29.3 29.6
40 ==============> 40.5 40.1 40.4
50 ==============> 51.0 51.0 50.8
60 ==============> 62.8 63.0 63.0
70 ==============> 72.5 72.7 73.7
It is most accurate at 40 ft-lb (about 1% error), 30 and 50 (about 2% error), at lower and higher end of the range, the error is about 4%~5%. Not bad for a low cost torque wrench, but we can clearly see the non-linearity of the accuracy.
My Snap-On Techangles seem all within 1% across the range, even though I didn't do a thorough test.
IMHO, if you are doing anything requires accuracy (such as engine work), digital is the way to go. The old clicker type, no matter the brand, is inherently not as accurate.
