whackywaxer
I have heard it is best to store a Torque Wrench set to a low setting near the bottom of the range but not at zero ......is this true...?
whackywaxer said:I have heard it is best to store a Torque Wrench set to a low setting near the bottom of the range but not at zero ......is this true...?
I just got my Proto torque wrenches calibrated by Proto directly - came back with stickers saying to store them with setting on 20% of the scale.
I don't know of any adjustable torque wrench that has a zero setting on the scale. Most start at 20% of max. A 100 lb/ft torque wrench would start at 20 lb. You would want to set it to the LOWEST setting on the scale.
Precision Instruments split beam torque wrenches are one variety that do not need to be returned to the low setting, as there are no springs inside to be damaged, this is stated in the instructions that come with the tool.
Charles
We have to store everything at the lowest setting at work other than the non adjustable ones of course.
We have several thousand dollars of torque wrenches from 5 in lbs to 1800 ft/lbs. Some go to the calibration lab every 3 months. Brand new stuff goes in before it goes into service as well. It's amazing how many BRAND NEW one I have kicked back because they couldn't meet spec. Ordered 4 new Matco ones a while back, all 4 were WAY off and 2 were so bad they couldn't be adjusted enough to calibrate correctly.
I have had great luck with Craftsman of all things though. $75 torque wrench that calibrates way better than a $350 Snap On, how does that make sense?
