2001ZR2
I have access to calibrating torque wrenches at work so I had the tech test my Craftsman Mircotork 44595 1/2" 20-150 ft/lb and the Pittsburgh Pro 1/4" drive click type Torque Wrench.
No there two wrenches were purchased based on price point with the Craftsman coming home with me from the Sears Outlet and the Pittsburgh a Sunday Afternoon Oh Sh*t! moment for getting an intake torqued to 11 ft/lbs yes 132 in/lbs.
The Craftsman passed with flying colors to our +/- 4% standard
50 ft/lb was 48.5 ft/lb
100 ft/lb was 98.5 ft/lb
150 ft/lb was 150 ft/lb
Now the Harbor Freight didn't pass even though I got a calibration certificate
50 in/lbs was 44 in/lb four percent is 2 in/lb
100 in/lbs was 91 in/lbs not +/- 4 in/lbs
150 was 140 not 6 in/lbs diff
200 was 186 not 8 in/lbs variance
The torque wrench is consistent and repeatable which means my intake bolts are torqued down evenly. I have a heavy hand so I think the bolts are tight enough and know the intake is sealed. No massive vacuum leak, no oil in the water and no water in the oil.
Just heads up that the Harbor Freight certs in not reliable in this case.
