Torque wrench tester
Cjcycles
NC
I’ve used one of those little digital torque meters you connect like an extension. Checked a few of my torque wrenches on the snap on truck. Then compared with the little digital meter and got the exact same results. Your mileage may vary, but it’s a cheap solution to spot check them.
kbuhagiar
Escondido, CA
This. :thumbup:
It's worked for me for the last ten years or so.
visionguru
Chicago
Z
zippster
Iowa
I have one of those Quinn units. Read good things about them and some guy on youtube tested one that came in under 2% spec. Mine however is 12 percent off. Anyone know if these can be re calibrated?
ddawg16
S. California
I'm a cheap *******.......and I like physical standards.
If checking temp accuracy? Make an ice bath and boil some water. 32-212 deg's F...compensate for altitude....it's about as accurate as you can get.
Torque? Clamp the head in a vise....hang a weight off the handle at exactly 1'....or 2' if you have a big *** wrench. Key point here is accurate weight. An easy way to take a small 'known' weight and check a high range is to use a long pipe and slide it on the handle. A 10' pipe would take a 10 lb weight and make it a 100 lb weight on the torque wrench.
If you don't have an accurate 10 lb weight? Get an accurate measuring cup.....a gallon of water weighs 8.34 lbs. At 10' from the center, 83.4 ft lbs.....
I love math.......until tax time
jessesandy
Upper California
Also, when hanging weights from a torque wrench handle, the handle must be parallel to the floor to make the test accurate. Imagine hanging a weight on a handle that was pointing down, the wrench would see very little "rotation" at the business end.
ddawg16
S. California
Thank you for pointing that out.....its a very important point.....I should have stated it
seber
Deep East Tx.
When hanging weights on a torque wrench you need to figure in the added weight of the wrench itself. I used load cells in some of my engineering designs. They can be accurate but the ones I consider good enough for a torque wrench would certainly not sell for the price of that HF unit. I'd much sooner trust the mechanical one in the original post.
visionguru
Chicago
How do you know it's 12% off? A strain gauge (torque sensor) is used in those digital torque adapters (wrenches). That much error indicates QC issue, no easy way to be recalibrated, except replacing the sensor.
I'd buy a new one from Harbor Freight and return the old one, because you were sold a defective unit.
I have a Powerbuilt unit. It agrees with 3 of my Snap On Techangle wrenches, very accurate.
chipjumper
Central Wisconsin
I’ve always done the digital luggage scale check by putting the torque wrench in a vice and pulling on the handle at 12” or a marked point then doing the math. Obviously I can’t quite pull 100lbs with my little fingers but it’s accurate for the <50 lbs.
SeisMec
Beryl, Utah
You are assuming the 10 foot pipe weighs nothing.
lardy1
I've got a variation of that cheapo torque adapter. If I check it against a beam type torque wrench, it's as accurate as my pull. I test my click type torque wrenches against both and have always been where I wanted to be.
Mgdoug3
KY
I use a beam style torque wrench to test against my other torque wrenches. I used an Allen socket on one and the corresponding hex socket on the other.
