Torque wrench..
dogdad
Down south
What's a decent torque wrench to buy...need it on the smaller side of ft pounds...10 ft pounds and up...actually for a Big Green Egg for the first use.
kd3pc
Northern Neck
so it takes a torque wrench to put a grill together that cannot be bought online??
My grill came with finger tight wing nuts...and if you tightened them too much they slipped...
I would go with the PI
pbon
I have a set of HF wrenches in 1/4, 3/8, 1/2 and 3/4 and also a digital torque measuring device to test their accuracy. I am also putting together a set of better wrenches and so far have the Precision 3/8 that goes to 100 lbs and the Precision 1/4 that goes to about 200 inch pounds. I plan to add the Precision 1/2 that goes to 250 lbs. When I am torquing connecting rod bolts, I want the good wrench.
D
dogdad
Down south
No it does not require one..but two bolts need to be tightened to a specific....so just gives me a reason to get a new tool.
redvalkyrie
Harbor Freight, used Craftsman, Tohnichi, Tone, Toptul, Tekton. The Tekton are very nice, made in Taiwan, and feature 1/4-1/2". They usually run about $30.
kctyphoon
Jersey/Staten Island
+1 for the HF. Just store it without tension on the spring. They have been repeatedly proven to be accurate so long as your not working on the mirrors for the Hubble Telescope.
For the applications where a torque wrench should be used, the real idea is keep multiple bolts applying the same or even pressure. Where single bolts are applied, it's usually to keep things within a range of torque, so things aren't grossly over or under tightened. Being slightly off from being "within NASA spec" won't really matter.
Wamsutta
Amarillo, Texas
You guys with the PI split beam torque wrenches:
Does the handle feel OK? Looks like it would feel like holding onto a pipe.
disston
Silver Spring, Md
I own several older Sturtevant beam type torque wrenches that I bought used. They are often pretty cheap even on Ebay. Watch out tho and watch the ads for a while before you buy. There are a lot of these being sold way above their value.
I then buy used clicker name brand wrenches. Names like Bonney, Utica and several others were quality tools only a few years ago. I use the beam wrenches to check the setting of the clickers when I use them. Beam wrenches don't usually lose too much of their accuracy. The clickers are easier to use and are a plus when doing multi fasteners that all need the same setting, like intake manifold bolts, or oil pan bolts.
