So I'm in the market for another torque wrench. Have considered buying used, so I was trying to scour the internet for info to either convince or dissuade me on the idea. I ran across the Wikipedia article on torque wrenches, and read something I've never heard before:
There are no sources that back this, so I'm taking it to Garage Journal. What do you think? Any merit here?
For the click type, when not in use, the force acting on the spring should be removed by setting the scale to 20% of full scale in order to maintain the spring's strength. Never set a micrometer style torque wrench to zero as the internal mechanism requires a small amount of tension in order to prevent tool failure due to unwarranted tip block rotation. If a micrometer tool has been stored with the setting above 20% the tool should be set to 50% of full scale and exercised at least FIVE times before being used.
