Torquing with impact sockets
IDidntDoIt
For torquing hub nuts (say 30mm) would it be okay to use impact socket, or a 3/4'' socket with an impact adapter from 1/2'' drive (1/2'' torque wrench)? Would it provide an accurate reading? I'm torquing up to 200 ft lbs so I'm not so sure that any flex from an impact socket is going to throw off the accuracy more than 10 ft lbs, but I just wanted to make sure.
G1GRANDEUR
I don't think it's going to be a problem. Though I'd skip the adapter if possible.
I
IDidntDoIt
Cool thanks. I guess I'll need to buy a 30mm 1/2'' drive socket to avoid using the adapter.
Alchymist
Central PA
Neither the socket nor an adapter should throw off the reading - the wrench will continue to apply torque to the train until the setting is reached, and the only thing resisting the torque is the fastener.
diesel research
gulf coast, TEXAS
Neither the adapter nor the impact socket are going to cause you any amount of issues under normal circumstances.
There is this myth that impact sockets are significantly "softer" or more flexible. That is not how they should be thought of. Instead, think of them more like a pyrex baking dish vs a wine glass.
I do prefer grey pneumatic adapters though.
G1GRANDEUR
Actually every attachment to ratchet will throw off the reading. It's best not to add anything between socket and ratchet for precision reading. But we are talking about hub nut, so no big deal. :thumbup:
diesel research
gulf coast, TEXAS
That applies mostly for impacts, where each square drive absorbs shock impulses. Unless he is hammering on his torque wrench or experiencing torsional twisting of any significant amount, he isn't going to have issues.
One could argue the theoreticals that there is always some torsional twisting, but the socket and single square drive also experience that. Even more important factor is frictional inconsistencies of the thread itself, and it's torsional twisting.
The bolt is going to twist before the attachment does, or else you have some junk tools or incorrectly sized.
Spam16v
B-low NY
torque spec on a hub nut is typically tight as hell.... Do not lose any sleep tool-polisher style.
Boiler
Indiana
Adapters don't affect torque as long as the torque wrench is acting in a plane perpendicular to the fastener and the drive of the torque wrench shares an axis with the fastener. Torque angle will be affected by twisting adapters and extensions however
larry_g
oregon
Adding additional torque to the input will be transfered to the opposite end of the shaft or the output. Remember the lesson in physics that for every force there is an equal and opposite force. When motion stops and everything is in equalibrium the torque in = torque out. So all torque that is applied to the torque wrench is seen at the load. No torque is lost in the adapters or extensions or anything else between the torque wrench and the nut or bolt. You may loose motion as the adapters wind up and energy lost as heat if you want to measure it but when all input motion is stopped what ever the torque wrench is indicating is being applied to the fastener.
lg
no neat sig line
PSYKO_Inc
Fairfield, CA
As far as I know, the only difference between impact sockets and chrome sockets are the lack of chrome plating (could flake off), and thicker walls to prevent cracking. If anything, the impact socket should flex less than the chrome socket. Either way, socket flex wouldn't make enough of a difference to even worry about, considering that calibrated torque wrenches are generally only calibrated to +/-3% anyway.
joeswamp
Massachusetts
Socket or adapter flex doesn't matter. You're applying torque to one end of a flexible adapter, no matter how much it flexes it's going to apply the exact same torque out the other end.
The situation is analogous to a spring sitting on top of a bathroom scale. If I put a 100lb weight on top of the spring, the bathroom scale is still going to register 100lbs, no matter how much the spring deflects.
