Torx Driver Set, Pratt-Read or Felo WWGJD?
Hootbro
Delaware
You need to look at the size ranges. The Felo are T6-T25 and the P&R is T10-T30.
Me personally, if I was looking for a basic set, I would get the P&R set as it seems to be in a more frequently encountered useable range than the Felo set. You rarely see below T10 stuff in most general maintenance use unless you are dealing with computer and electronics
assemblies.
Here is a better Felo set in the T9-T40 size range.
http://www.amazon.com/Felo-0715750979-Screwdrivers-T9-T40-Series/dp/B000E6657W/ref=pd_cp_hi_2
Jawn
Stuck in traffic, GA
assemblies.
Pratt-Read also has a T5-T9 set if one would need smaller sizes.
As to the handles... I haven't used the Felos, but personally I like the Pratt-Read handles.
shoturtle
Frankfurt AM
pratt and reed are good drivers, the tips are not bad. But the felo have a harder tip, it will wear better the the pr.
C
CarbonCrew
South Carolina
For now, I ended up going with the Pratts only because they are American made. I sort of prefer those 'old school' clear handles too. They should be here tomorrow. Thanks for the replies.
