Tow chain storage ideas?
biggziff
Upstate NY
Before I insulated my shop I had 2X6 wall bays and I had some heavy angle bolted to the studs and I could store the chain in those bays. Now, my walls are insulated and finished so that option is gone. I have 6, heavy tow chains to store, probably 250+ pounds. I can weld up some brackets and stand the angle I have now off the wall a few inches, but someone that is more clever than I am probably has a great idea I can copy...so...tell me what that idea is!
Thanks
Bogie1632
Southeastern Wisconsin
I like storing the chains on a stand so that idea is good. Past one I built for a shop I added wheels so we could move the stand when needed. Made it easier to load into a truck or have all available for tow or lift at our crane.
V/R
Bogie.
Lassen Forge
Decades ago, we built stands made of IIRC 2" pipe that we used to hang them from - spray them down with "shop spray" - a 50/50 mix of 15-40 motor oil and WD40 in a spray bottle - to keep the rust from starting. Nowadays at home I hang them on the 4x6 support beams for the overhang outside the shop, also sprayed down with shop spray.
Throbbin Rods
Lebanon, NH
I screwed some flat stock to the wall studs and in each bay I have a chain doubled twice and laid in there so I can just grab the hooks and pull out the chain I want. Short chains hang full length. Doesn't take up any floor space and keeps them handy
freudianfloyd
Nowhere
My grandpa has a chain stretched across the wall in his barn with all of his log chains hanging from it by their hooks. Works good and keeps them separate and up off the ground.
lis2323
On the wall for me.
csp
Franktown, CO
I have pallet racking in my shop, so angle iron was bolted across one upright end. Chains are hanging from that angle iron.
kbs2244
mine are 50 foot 3/8 chain
they fit in antifreeze jugs, with a pair of gloves, just fine
Mattlt
MN
A piece of C-channel iron bolted to the end of a shelf.
toolmiser
La Crosse, WI
On a related note, I was moving some of my chains the other day, and I took the time to use a paint marker on the ends to write the length. Kind of a senior thing.
bad_idea
Pasquotank, NC
Ammo Cans are good. They are strong and stackable, plus they have strong handles.
That's what I do with mine. I mostly use mine with my jeep and occasionally with the truck to pull stumps. Either way, I'm carrying them to a vehicle. The smaller ammo cans are great as they hold one chain (25' 3/8 chain with hooks) and a couple accessories - keeps the weight down.
I store mine in a 5 gallon bucket, but keep it out of the rain (or drill holes in the bottom) our you will have a rusted mess.
I have a second bucket for tow strap, shackles, etc.
bad_idea
Pasquotank, NC
Talking about buckets - I love the Tidy Cat litter buckets. The square shape stores well with minimal wasted space. Can't stand the cat in the house but love the buckets.
Sevenhills1952
Virginia
I like to spray mine every couple feet with fluorescent red...then silver, etc. a few places. Easy to find especially in tall grass.
As other's said WD and/or oil. Buckets are good.
Sent from my SM-S320VL using Tapatalk
mmb617
PA
I only have one but it's heavy duty. I keep it in a canvas bag behind the seat in my truck because chances are real good that if I need to use it the truck will be involved.
