Hello All, I may have posted this in the wrong section. Sorry if I did. I just bought a tow dolly. I think it is a Master Tow. There is a bar that runs from one wheel assembly to the other. When you remove the pin that holds it stationary, you can pivot the wheels from side to side for just a little ways. What is this called and what is it for? When towing a car should this pin be removed? See the picture below. Also when towing a car should the steering on the towed vehicle be locked or left loose to turn? Thanks Terry
