TOYHAULER/CAMPER from scratch
RedRob
Nova Scotia Canada
Hey guys I have a little project that I have been working on since last fall
I collect and restore vintage motorcycles and minibikes and I needed a way to haul them to shows as well as the extra storage because as you all know your garage is never big enough
It started out as the frame from a 26 foot camper , tandem axle with electric brakes
The previouse owner had stripped it down to the bare frame for a flatbed but lost interest I picked it up for $400
Then the planning began , I ended up cutting it down to 17 1/2 feet a more useable size
I know everyone loves pictures so here is a few of the progress
The frame when I got it home
Then I started decking it in
After it was decked in I started framing the walls from 2x2 spruce , I built it inside out so the 1/4 miranti sheathing is on the inside
Then I stood them up and started on the rafters
Then the outside was insulated and the wireing for the lights
The outside was skinned with shiny white aluminum sheets and the corners are trimmed with 3/4 x 3/4 aluminum angle
The doors are 3/4 plywood with the aluminum bonded to the outside and the edges wraped with 3/4 aluminum channel
The windows are 1/4 plexi set in rubber moulding
The inside is more functional than luxory lol , but it has a fridge , counter , sofa/bed and a bathroom portapotti closet
It will have two fold down bunks in the back
Still lots of finishing touches to do
Started wireing up all my lights today.
koditten
Midland, Michigan
Whay cool.
Why did you hinge the side door that way? I would think having the hing on the oposite side would make more sense. If the latch gives, your door will swing open while under way. The wind could rip it right off. Not saying right or wrong, just curious.
KO
Did you coat the underside of the deck with anything ? I would be paranoid that it would absorb moisture and turn soft over time.
R
RedRob
Nova Scotia Canada
Thanks guys it has been a fun project
I pre painted the bottom side of the plywood with two coats of extirior oil stain bfore it went down
The door hinge question lol
Well I could lie and say I was left handed
It was a tough choice to hinge it that way I didnt want it to cover the window when it was open and I wanted a heavy duty grab handle for my right hand
I worried about the blow open thing to but I am useing garage door style hardware that has a heavy slide bar
More pictures to come as it nears completion
Thks Rob
R
RedRob
Nova Scotia Canada
Thanks guys its final crunch time to get it finished
I will be heading to Pa on the 10 th of june
Just a short 20 hour drive lol
I picked up 4 new tires and rims for it and had a look at the brakes and bearings
The bearings look fine but I may change them , its cheap insurance lol
The brakes were looking rather shoddy so I found out that It was cheaper to buy a complete assembly inc electromag than to buy shoes and a spring kit lol
Still have lots to fo but its getting closer to completion
Rob
Arps
Indiana
I work at an RV factory and it looks like you are doing a good job, but I would suggest a moisture barrier of some sort between the frame and the floor. We use a stiff plastic that is similar in build to corrugated cardboard, as well as a plastic sheet (woven kinda like kevlar to prevent tears) and spray in insulation.
R
RedRob
Nova Scotia Canada
Thanks for the tip Arps
Yes the roof is the same aluminum sheet as the sides
All of the seams on the sides are are over lapped and sealed with an industrial 1 1/2 " wide double sided tape and screwed every 6" with stainless steel screws
The roof seams are overlapped and have butyle rubber tape between them
And then caulked with a butyle rubber sealant
geologist
What did you use to bond the aluminum to the plywood doors? I'm needing to build some new doors for my cargo trailer.
