Tpms. Install question
J king
Ne oh
Hi. I just repainted the wheels on my GM. I am reinstalling the tpms sensors and was wound earring if I should put anything on the rubber seals I am not replacing them..is that wrong.Figured they would be hard to find separate. Thanks. Jim
Tim C
Just install them dry and snug them up. That's all we do at work. Just snug too, the sensors will break pretty easy.
Showkey
"MEMBER EMERITUS"
Wausau WI
I think if you read the "shop manual"..........it will say:
Do not reuse the seals.......
Torque the nut to a very specific value....
No sealant.....
What is actually being done in the field ???????
willyswonka
New Orleans, LA
No sealant, torque the nuts to 11 lbf. If you want to replace them, any high volume tire shop should have tpms kits with new gaskets, valve cores, and nuts.
Showkey
"MEMBER EMERITUS"
Wausau WI
General info:
What is the torque value required for the nut?
Typical torque values for the base nuts on a TPMS valve stem range from as low as 35 in.-lbs. of torque to as much as 80 in.-lbs. of torque. That’s quite a range. This doesn’t mean that any torque value within this range is acceptable. It means that the torque specifications for the base nut on one vehicle might re*@#$quire 44 in.-lbs., another might re*@#$quire exactly 62 in.-lbs., yet another might specify exactly 71 in.-lbs., and so on. Don’t guess. Look up the torque specifications for the vehicle you’re servicing to make sure you use the correct torque.
Why should the nut be replaced every time a sensor is serviced?
The nut is made of a softer metal than the stem, so it will be damaged – not the sensor – if it’s overtightened. The material of choice is typically aluminum. If the nut is over-tightened, it will develop hairline cracks.
