Trading down on my engine hoist
jmarkwolf
Southeast Michigan
I currently have a nice AC Delco 2 ton engine hoist. I don't do any engine work and just use it as a general purpose shop crane. It's well made from heavy thick wall rectangular tubing.
My only complaint is that it is not the folding variety. The legs have to be lifted vertically out of their "keepers", then slid horizontally into the "receivers" and pinned. I would guess each of the thick wall legs weigh 75lbs or more (and they're getting heavier every year!). Getting the angle of the dangle just right for the legs to slide into place is a struggle (almost a 2-man job).
Reversing the process for dismantling the hoist for stowage is a bit of a chore as well. I sometimes have second thoughts about using the hoist for this reason.
I'm thinking of selling the hoist and buying the HF 2 ton engine hoist. It has the same stated capacity, and has folding legs, so I would only have to lift one end of each of the legs while deploying it. It is not built as robust as my AC Delco and I understand it will not have the same "practical" capacity, but I've never had the need to lift anything heavier than my 1200lb lathe. I expect the HF 2 ton hoist should have no issue with that load.
The alternative is to modify the legs on my AC Delco hoist to fold, which would likely compromise the capacity and/or stability, and probably cost more to modify than the difference in cost between selling the AC Delco and buying the HF.
Trying to avoid buyers remorse. Any thoughts?
Mark_17
I have a HF 3 ton and no regrets. It does what I need it to and folds up out of my way
brianh
grahamsville NY
I have the folding 2 ton it works well I use it outside a lot so I welded axles for pneumatic hand truck tires. It rolls real nice compared to the steel wheels.
Jswain
Calgary, AB
The fact that you can flip the legs down and get going will keep you from doing stupid **** or trying to manhandle things because the other ones a pain in the *** to setup so that alone far outweighs the bonus of having a heavier duty model, unless you are taking things to the extreme limits which you already said you aren't.
It would be a no brainer for me the AC Delco would be cleaned up and on the buy/sell by now lol.
brownbagg
i have had the hf folding hoist about 20 years now, and think its great, omly think i dislike is the handle and the lowering screw, i like to change that out
unslow1
Illinois
I got rid of my big hoist a few years ago. The space it takes up just wasn't worth it. Now I have the HF folding one. I'll never be able to pull the engine on a Suburban with it but it takes about 1/4 the space.
mikester
small town NY
I bought a folding hoist from Autozone which is a rebranded/repainted Torin. Turns out Torin hoists are sold by Autozone,Advanceauto,Pepboys and NAPA. Just different colors. That info was directly from Torins customer service.
Pepboys had them on sale but were out of stock. Went to Autozone with the sale flyer and they not only matched the price but they beat it.
harley jim
Cleveland Tn..........out in the sticks
I have a folding cherry picker not sure if its HF or not but looks like it. Anyway I added this to help me be able to work with it alone. It will pick up the front of my CJ5 easily.
I like the folding legs to get through tight spots and for storage, with this cylinder I can control my load and lift at the same time.
Sent from my SM-A102U using The Garage Journal mobile app
Sumboodie
AK
The whole thing weighs 185lbs. No way just the 2 legs are 150lbs. Maybe 75lbs total.
I'd do a little cutting and welding to make it how you want.
Ign
Butte Peak ND
Yeah this isn't rocket science. I'd just mod what you got, but metal fab is what I do everyday
