PretendMechanic
I'm building a light duty small 5x8ish trailer and need low ground clearance and independent suspension. It will be constructed out of square tubing and start it's life as an open deck trailer. Will upgrade it to enclosed in the future continuing with a square tubing frame.
The more I search regarding axles, I just find more and more manufacturers, and don't know where to begin.
I like this style of design that allows to adjust ride height and has independent suspension. I also like how simple it is to affix to a trailer. I believe they are called "Rubber Torsion Half Axle". The one pictured is called Flexiride and made by Universal Group
I see many manufacturers make this type of axle, with prices varying wildly.
I'll only be pulling less than 500 lbs including the trailer for now, so nothing heavy duty is required. Though my trailer will be able to support the towing capacity of my vehicle, which is about 1600 lbs. So I'd like to look for something around that capacity. Easy bolt on brakes for future upgrading is also a factor.
Is there a known quality US brand? Only prefer US for ease of parts availability, I don't care where the product is made as long as it's quality. Cost is a big factor.
Are there any other designs of axles that I should be looking at?
Yes, I thought about buying a pre-built trailer, nothing on the market suits my niche needs.
