Trailer deck sealer
racecougar
Missouri
Assuming you used oak? Boiled linseed oil, thinned motor oil, or any of the myriad oil-based deck stains.
jack stand
Lakes Region Maine
Replaced with what kind of wood?
I'm in the oil camp with racecouger but wet PT or sawmill lumber need a little time to dry out before oiling.
mikegt4
sw ohio
I use old anti freeze when I change it out on my vehicles. I use a garden sprayer to apply it to the deck, seems to kill off any rot spores. My trailer still has it's original treated SYP wood deck, it's still rock solid after 25 years of sitting outside year round.
ericm
Southern Oregon
For $15 or so I got a gallon of deck sealer that's not toxic like used motor oil or antifreeze and is actually made for the purpose. It's even got UV stabilizers. I used half of the gallon for an 20' deck so I can treat it again for free next time.
Hank11
Tennessee
Using oil whether new or used is a great way to have a nasty trailer deck. Deck sealer, or even better a deck stain or finish it so much nicer.
mike93lx
Richmond, VA
Hopefully white oak and not red.
I'd never put used motor oil, diesel, or hydraulic fluid on a trailer, but know many guys here do it. My choice for trailers has been deck stain
Hank11
Tennessee
Every trailer I've seen with used motor oil
-seems to last
-is as slippery as an ice rink covered in KY when it gets wet
Ymmv
Why would anyone want this?
”-is as slippery as an ice rink covered in KY when it gets wet”
And generally nasty.
u2slow
BC
Forget about sealer. You can't fully seal water out, and a coating will inhibit drying. Just like a wood deck on your house.
I will be looking for an oil treatment of some kind when I renew the wood on my trailer.
JeepYJ
Because it’s not either of those.
Wood in general is slick when it’s wet. Rough sawn white oak would the least slippery.
Used oil darkens the wood slightly to a lot (depending on how much and how often you apply it). An oil based wood treatment is, wait for it… oil based.
racecougar
Missouri
Thinned motor oil, hydraulic oil, linseed oil, or an oil-based deck stain is not slick at all on rough sawn white oak. It soaks in right away. If you're using smooth, pressure-treated, SYP, that's a different story. Those boards will be slippery when wet as-is, and aren't a particularly great choice for decking an equipment trailer. Hence my question in the first reply on this thread. The OP has not returned to tell us what wood he/she is trying to seal.
You can also thin an oil-based enamel down to soak into the wood. Awfully fancy for a trailer though, IMO.
jack stand
Lakes Region Maine
This reminds me of a guy that did chainsaw carving. He treated with antifreeze also. I'd say you're 25 years is proof enough. 👍
I like used oil but it can be slippery for a while especially wetted by rain.
ATC
VA
I almost went with used oil, but in the end, I just used the cheap Thompson’s water sealer
Mikes61
Black oil based stain. It matches the black trailer and has held up very well.
