bubinga
I have a little Harbor Freight trailer. The factory brackets for the tail lights broke at the 90. Made a new bracket out of some probably about a hundred thousands of an inch corrugated metal inch and a half or 2 in wide. I guess my Bend ended up at one of the holes anyways no big deal I thought well that bracket cracked right there and broke, keep in mind every time it does this, it is dragging my trailer lights on the ground and messing them up. I also use this little L bracket that worked out perfectly that came with a fluorescent light fixture I got. Well guess what that cracked at the 90. What do I need to do? If I were to go get some heavier steel some place I'm thinking maybe one eighth 0r 3/16 " of an inch thick, by about 2 in wide, if I were to get it cherry red and heat bend it do you think that would help the metal from fatiguing and cracking? Getting tired of having to bungee chord up my trailer lights. I am going to have to buy some new lights and I don't want to be dragging them on the ground. The scrap yard around here that pays the best, you have to drive about a quarter mile down a pothole city road. That is where the last bracket broke. I have gotten good at recognizing the sound of my trailer lights dragging on the road. Thank you.
