Question: In replacing the front and rear spring hangers, can I just measure off of the center spring hanger (that is not going to be replaced)?
Details:
I had two 3500lb axles without electric brakes. It's fine for hauling circle track and demolition derby cars that are stripped down, especially with a dually. I now haul a tractor once every six weeks in the summer. The trailer frame is on par with 10,000lb trailers I've seen. The tractor is heavier than cars and I wanted the better axles with brakes. I upgraded to two 5200lb axles with electric brakes. Since the axle tube is bigger, I have almost no suspension travel. A trailer manufacturer recommended I use the 3 1/4" hangers on the front and bad, not just the center. The hangers I bought are made from the same flat bar, dimensionally they are the same. Can't I just cut off the old front (and rear) hangers and simply measure from the edge of one hanger to the edge of the center hanger to keep the bolt hole along the same vertical line from the trailer? Said a different way, the new hanger is in the same location as the old, the spring mounting bolt is just lower vertically, no change to its location from front to back. I would put a piece of flat along the frame during welding such that the new hanger is not twisted so as to not bind the leaf spring.
Is there anything I am missing?
Details:
